Author Topic: axle tag  (Read 2077 times)
Offline c9zx
axle tag
« on: April 21, 2011, 03:23:27 PM »
I have figured out that the "plant code" 955B indicates a 3.25:1 gear set, non locking differential. Does 955A indicate same ratio with locking differential? 1972 Q code, 9 inch differential.
Thanks, Chuck
Thanks, Chuck
1969 G code Cougar Eliminator
CSX 7031
Offline svo2scj
Re: axle tag
« Reply #1 on: April 21, 2011, 05:31:36 PM »
NO
According to Marti Tagbook the suffix (added after 1969) is for internal engineering change
Mark
WFB-C or C2 is 3L25 (locking)   WES-AD2 is 3:25 open
« Last Edit: April 21, 2011, 05:34:56 PM by svo2scj »
Offline c9zx
Re: axle tag
« Reply #2 on: April 21, 2011, 10:18:54 PM »
Thank you for the information. By any chance does the tag book indicate what the "plant code " is for 3.25:1 28 spline locking? The reason I ask about the A meaning locking is the 2 Boss 351 axle tags I've seen have an A suffix.
Thanks Again,
Chuck
Thanks, Chuck
CSX 7031
Offline svo2scj
Re: axle tag
« Reply #3 on: April 21, 2011, 10:28:02 PM »
The the "plant code" 900 series is Mustang/Cougar.
IF it is 28spline then it should be WES code (and not locking)
Mark
P.S.  Again the "suffix" is called out as internal engineering change (doesn't matter if Boss 351 )
Offline c9zx
Re: axle tag
« Reply #4 on: April 22, 2011, 10:44:28 PM »
Chuck
Thanks, Chuck
CSX 7031
