Author Topic: Convertible top motor and hydraulic lines  (Read 715 times)
Offline Anghelrestorations
    • Anghel Restorations
« on: April 27, 2023, 11:39:48 PM »
I assume that the convertible top motor and the hydraulic lines are the same for all years but since I am working on a 65 Mustang will post in this section.
Putting together all the lines best I could tell is correct but just wanted to confirm.  Unfortunately the photos I took on disassembly are not clear enough where you can see what lines are going where....so I know there is a 50% chance I am correct.
I have the lines that go to the front of the motor route down to the bottom of the cylinders now.  I assume if this is wrong then the top switch will work backwards.
Pictures here of current set up....
20230427_181151 by Marcus Anghel, on Flickr
20230427_181127 by Marcus Anghel, on Flickr
Marcus Anghel
www.anghelrestorations.com
Re: Convertible top motor and hydraulic lines
« Reply #1 on: April 28, 2023, 12:38:40 AM »
The routing is shown in the "1965 Mustang Body Assembly Manual" (AM0006) pg 58.
Need I go into more?
« Reply #2 on: April 28, 2023, 03:15:00 AM »
Thanks Jim.  Its all routed correctly according to the assembly manual then.
Marcus Anghel
