Author Topic: carburetor dashpot  (Read 9933 times)
Offline MattDoscher
carburetor dashpot
« on: April 20, 2011, 07:02:00 PM »
I have a 289 engine, autolite 4100 carb, C4 transmission and A/C in my '65 coupe.  Do I need a anti stall dashpot on my carb?  I currently do not have one and was wondering what purpose a dashpot serves.  The shop manual doesn't really describe what the purpose is only how to adjust it.  I did a search on this forum for dashpot and saw that one commentator had installed a hot idle compensator in the PCV valve line.
thanks,
Matt
Matt Doscher
5H25T582252
Re: carburetor dashpot
« Reply #1 on: April 20, 2011, 08:26:00 PM »
dashpot was only used with an automatic trans. its purpose was to prevent the throttle from slamming shut and possibly causing the engine to stall.
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
« Reply #2 on: April 20, 2011, 10:00:34 PM »
If you are stopped at a red traffic light, and the guy to your left takes off, and so do you.  Then you quickly realize your light is still red, and in a fraction of a second, you take your foot off the gas and stomp the brake.
This will almost always cause the engine to die... UNLESS YOU HAVE A DAMPENER (dashpot) to lower the throttle the last 5%,slowly.
There was an OEM one on Ebay a few weeks ago for $38.
66 Metuch Conv
Nightmist, Std Blu Int
Offline dave6768
« Reply #3 on: April 20, 2011, 10:01:05 PM »
I drove my 67 for about 30 years without one without any issues.  I only recently added one to make it look concourse correct.  However, I did not see any difference when I added it.
Dave
Offline bryancobb
  • 2009 Ridn' Around
« Reply #4 on: April 20, 2011, 10:17:03 PM »
Dave
It's worthless it it ain't working.  If you have a WORKING one, and you have it adjusted right...IT"S SCHWEEEEET!
Rev the engine...instantly remove your foot off the gas...the RPM quickly goes to 900 and then S-L-O-W-L-Y eases down to a stable 600RPM idle in 2 or 3 seconds.
I bought 3 off Ebay, including a bad (new) one from Pony Carburetors, before I got a working one.  The working one I got was for an NOS 66 Chrysler product that was exactly like the Ford one except the threaded stem was longer.  I cut it on the lathe to the right length.
This is the exact one I bought  (Item #310309713437)  $50 Buy It Now.
66 Metuch Conv
Offline MattDoscher
« Reply #5 on: April 21, 2011, 04:48:20 PM »
Thanks for the replies guys, I appreciate your insight.  I understand what your talking about Bryan.  Mine will do pretty much the same thing if I gas it real quick at idle the engine will just about cut off until the idle circuit catches up with it.  So I can see where a dash pot would help.
Matt Doscher
5H25T582252
