Author Topic: 67 power steering return hose clamp  (Read 1248 times)
« on: April 10, 2023, 09:45:12 AM »
Looking to confirm or correct the power steering return hose clamp I found on my car.  It appears to be part number 97237, and not the alternate 97201.
Mine has one of two nut retainer tabs busted off - is there a source for these other than a junkyard?
Re: 67 power steering return hose clamp
« Reply #1 on: April 10, 2023, 12:41:10 PM »
 Wittek hose clamps of various sizes are frequently sold on Ebay. NPD sells one that is similar.
« Reply #2 on: April 10, 2023, 12:45:31 PM »
Check your broken clamp and there will be a large single number on the inside or outside perimeter of the band. The number is the best way to confirm if you are getting the correct size clamp remotely. Off the top of my head I don't recall what the number for the 5/8 size is.
« Reply #3 on: April 10, 2023, 02:47:02 PM »
Thanks Bob.  I can see Wittek stamped, but the large number or numbers is difficult to see.  I have a large collection of other Witteks so I'll go see what I can find and report back.
« Reply #4 on: April 10, 2023, 05:44:33 PM »
Found a good replacement - it is Wittek #23.  The assembly manual calls out the S8 zinc plate finish - is that assembly line accurate?
Offline Anghelrestorations
    • Anghel Restorations
« Reply #5 on: April 10, 2023, 07:30:15 PM »
Silver or zinc is correct finish on these from what I have seen.  I have some original Wittek clamps and can confirm the numbers when I get back to Arizona.
Marcus Anghel
www.anghelrestorations.com
« Reply #6 on: April 10, 2023, 11:40:28 PM »
I typically see silver on the PS and fuel line Wittek clamps of various years 67-70. Gold is typical on Wittek thermactor clamps.
« Reply #7 on: April 11, 2023, 08:51:21 PM »
Agree with Bob here on the finishes.
I found an original power steering clamp here and they were marked as a Wittek with a 2.  Ford used these but also some GM applications for power steering as well so you should be able to find them if you look around at swap meets etc.
Marcus Anghel
Offline Texascobra
« Reply #8 on: April 22, 2023, 04:09:46 PM »
After seeing this post I looked in my hardware bin and found these 2 clamps from NPD. The one on the left is PN 3A713-1k for 65-73 mustang PS hose. The one on the right looks like and measures out like the diagram at the top of the post. It is NPD PN 2344-1 for 55-57 Tbird PS return hose. FYI.
65 427SC 4123
67 GT500 752 1/23/67
96 Cobra American Iron Racer
12 GT500 Daily Driver
« Reply #9 on: April 22, 2023, 04:27:51 PM »
Have seen those and they dont resemble anything at all the factory used - from the screws to the clamp.
Original power steering hose clamps are not that hard to find and for what people are looking for on this forum, I would find originals and use them.
Marcus Anghel
« Reply #10 on: April 22, 2023, 06:47:03 PM »
Either will work and likely why NPD sells them. Does not mean that they are copies or reproductions of originals. If you restoring your car. agree with Marcus find some originals
« Reply #11 on: April 22, 2023, 11:24:35 PM »
Based on your past Shelby posts I thought I would make sure that you are aware that although the # 2 clamp that is being discussed was used on regular Mustangs it was not used on the 67 Shelby's. All of the clamps used on the Shelby were the crimp type clamps .
Offline Texascobra
« Reply #12 on: April 23, 2023, 10:23:35 AM »
I have the crimp clamps on my car. I just thought it interesting that the Tbird clamp had the same measurements and looked a lot like the clamp in the illustration.
65 427SC 4123
