Author Topic: 68 Cluster Wiring?  (Read 823 times)
Offline Bobsdad
68 Cluster Wiring?
« on: April 02, 2023, 09:52:19 PM »
Hi everyone, can anyone tell me what guage wiring is used behind the instrument cluster and are there any places you recommend buying wiring? Thanks.
Re: 68 Cluster Wiring?
« Reply #1 on: April 02, 2023, 10:37:25 PM »
First welcome to the site. Hope you find the information and support here helpful in returning or maintaining your car as it was originally built.
We have a section that focuses specifically on "Providers and Services"  Using the search I found the usual two answers to for purchasing or having your originals repaired. Be aware that not all of the reproductions are 100% like originals so take that into consideration.
For great information, knowledge and repair
https://www.concoursmustang.com/forum/index.php?topic=3.0
For new reproduction wiring you will find dozens of threads suggesting Alloy Metal Products. Such as this one
https://www.concoursmustang.com/forum/index.php?topic=3646.msg27834#msg27834
Direct contact or the wiring is resold through a number of the Mustang shops (as to make sure they are the provider) or member Coralsnake can often provide also
https://www.concoursmustang.com/forum/index.php?topic=13668.msg84531#msg84531
« Last Edit: April 02, 2023, 10:51:01 PM by J_Speegle »
« Reply #2 on: April 02, 2023, 10:58:51 PM »
wire size is typically 16 or 18 gauge.  If you want concours-correct wiring, Rhode Island Wiring sells wiring by the foot.
« Reply #3 on: April 03, 2023, 12:31:25 AM »
Rhode Island Wiring http://www.riwire.com/ sell a lot (it is two words) of other wiring repair items like the brass "button" that goes on the end of a wire inside a lamp socket, and replacement springs (think license plate lights).
Be advised that they don't use stock numbers to order items but use descriptions.
Offline KDunne
« Reply #4 on: April 03, 2023, 09:48:28 AM »
I recommend Coralsnake...(Peter Disher)
Offline Coralsnake
« Reply #5 on: April 03, 2023, 10:23:18 AM »
There are two instrument cluster wiring harnesses. One is with Tach and one without. They are reproduced and they are fairly accurate. The cost is around $150. Thats probably going to be your best route
Feel free to contact me if you need one
Coralsnake68@hotmail.com
Offline Bobsdad
« Reply #6 on: April 04, 2023, 04:40:03 PM »
Thank you all for the warm welcome and helpful information. Glad to be here.
Offline Kascus
« Reply #7 on: April 10, 2023, 10:08:10 AM »
Original style repo wiring harness (with tach).
Current:
1968.5 428 CJ Fastback / San Jose 05-15-68
1964.5 289 D Code Coupe / Dearborn 06-05-64
1966 289 C Code Convertible /San Jose 02-11-66
Past:
1965 Shelby SFM5S561
1966 289 FB
1965 289 Coupe
1969 302 Fastback
