Author Topic: 64.5 Fuel Filler Hose Clamps  (Read 941 times)
Offline Countrysquire
    • Houston Vapor Blasting
« on: March 24, 2023, 11:37:21 AM »
Are these original band clamps?  The tank and hose had been replaced, but these look old and I will restore them if so. They are marked 2.725, which I assume to be the diameter, and a ?C? in a trapezoid.
Bobby Crumpley
MCA#20316
www.houstonvaporblasting.com/
64.5 Dearborn Coupe
5F07D173***
65A M 86 20F 62 1 5
Re: 64.5 Fuel Filler Hose Clamps
« Reply #1 on: March 24, 2023, 02:18:12 PM »
Look right.  If you find a source let me know.  I have some that work, but they don't have the markings and are more narrow than originals.
« Reply #2 on: March 24, 2023, 03:08:51 PM »
Thanks Charles. I will work them back into shape before sending out for plating. I sure hope the plater doesn?t lose them, the engine ID tag, or any of the hard to find fasteners.
Bobby Crumpley
MCA#20316
64.5 Dearborn Coupe
5F07D173***
65A M 86 20F 62 1 5
« Reply #3 on: March 24, 2023, 06:54:31 PM »
Plating the engine ID tag?
« Reply #4 on: March 24, 2023, 10:20:45 PM »
I had read in a couple places that they were zinc plated, but that doesn?t make sense to me since the ID tag is aluminum.
Bobby Crumpley
MCA#20316
64.5 Dearborn Coupe
5F07D173***
65A M 86 20F 62 1 5
« Reply #5 on: March 24, 2023, 10:30:00 PM »
Why I asked.  :) Never hear they were zinc plated or finished from anyone but then again there is the internet  ::).
« Reply #6 on: March 24, 2023, 10:52:34 PM »
I'd be a little hesitant to zinc plate them as it may make them prone to crack when re-crimping.  Will be surprised if they re-crimp without breaking, regardless.  Be sure to use the correct original style filler hose and not the reinforced repro that has been sold for many years.
« Reply #7 on: March 25, 2023, 10:32:56 AM »
Makes sense. I will just give them a light polishing then some corrosion prevention and hope for the best.
Bobby Crumpley
MCA#20316
64.5 Dearborn Coupe
5F07D173***
65A M 86 20F 62 1 5
