Author Topic: Acapulco Blue in modern PPG DBC  (Read 3606 times)
Offline jmlay
« on: March 20, 2023, 12:51:35 AM »
I know these cars were originally painted in single stage. I have chosen to use base clear.
While I may be incorrect, it's my understanding of one goes to a PPG distributor and asked for Acapulco Blue, 3077-A/13357, the mix codes are only available in their ShopLine, unavailable in Concept (DBC). Is this accurate? Has anyone had an original paint car scanned and mixed in PPG Concept, base/clear?
« Last Edit: March 20, 2023, 08:11:29 PM by J_Speegle »
Mike
1969 Mach1 428 CJ Ram Air
San Jose
Scheduled Build: 1/2/1969
Actual Build: 1/3/1969
Released: 1/8/1969
Offline DragPack69
Re: Acapulco Blue in modern PPG DBC
« Reply #1 on: May 27, 2023, 11:12:53 AM »
Mike, I took my original mirror to my paint guy and he scanned and mixed exactly to the paint under the rear window gasket.
Not all paint guys can be that exact.
I think we're lucky as ours is about as good as they come.
Offline jmlay
« Reply #2 on: May 27, 2023, 10:48:28 PM »
Thanks for replying. Should have followed up on my own post. Unfortunately, the only original paint left on this car is on the trunk lid square tube. This surface are is not large enough to scan.
Since the original post I have reached out to PPG directly and was assured they have they have a mix formula in using bdc toners. Now to get a sample and do a few spray outs to match with the trunk hinges.
Mike
San Jose
Released: 1/8/1969
« Reply #3 on: May 28, 2023, 04:15:45 PM »
Thanks for the up date. Once you get the mix maybe you can post it to help others at least until PPG changes paint and mixes again
Offline jmlay
« Reply #4 on: May 28, 2023, 08:41:22 PM »
Absolutly!
Mike
San Jose
Released: 1/8/1969
Offline rodster
« Reply #5 on: May 28, 2023, 10:38:56 PM »
One of the best colors IMHO.  8)
1965 Dearborn Mustang Coupe
Raven Black - Palomino Pony
1967 Dearborn Mustang Conv.
Wimbeldon White - Red
1984 SVO - 2A
Offline 1969 Cale II
« Reply #6 on: June 06, 2023, 09:17:57 PM »
I use PPG paint on my resto's. Top coat is more important than the base, I use Omni Plus, this is your protection against uv and the weather. I am learning that PPG may not be able to mix some old colors because of no pigments. Get a half pint mixed and do a test spray. If it looks good go for it. Quality clear is most important
« Reply #7 on: June 07, 2023, 01:58:37 PM »
I had my local PPG dealer mix according to what they said was their "proper formula" based upon the original mix formula. This was for Lime Gold in DCC Concept.
It was several shades too dark.
I've used their special photo analysis camera of original paint done and the metal flake was incorrect.
I've asked and received formulas from others that said they had the perfect color but they gave me mixes for systems not available anywhere within a state's distance.
If you think you will get a proper mix without a very good paint man doing a dozen or so sprayouts on paint cards you will be disappointed.
Offline DragPack69
« Reply #8 on: June 16, 2023, 09:13:52 AM »
sorry , I forgot about his topic.
I just checked the number on my can of touch up and 13557 will match.
If you need more info, PM me and I will send you my cell#
Offline jmlay
« Reply #9 on: December 11, 2023, 07:17:34 PM »
The information I has received was incorrect. This is was mixed using the PPG paint code, 13557.
From what little original paint is on this car, this looks very close.
« Last Edit: December 11, 2023, 07:20:43 PM by jmlay »
Mike
San Jose
Released: 1/8/1969
Offline jmlay
« Reply #10 on: December 11, 2023, 07:23:27 PM »
This looks eat more green than what it really is. Lighting, camera, browser rendering, monitor, etc? all play a part in how it looks on your screen.
Mike
San Jose
Released: 1/8/1969
