Author Topic: 1970 Turn Signal Housings Plating?  (Read 784 times)
Offline rcgt350
« on: March 16, 2023, 12:23:24 AM »
I?m looking for confirmation on the plating finish for 70? Turn Signal Housings?
I thought they were Silver Zinc, but I?m hearing more now that Yellow Dichromate is correct like 69?s were if that still stands for 69? too.
1967 GT 350 W White
1970 Boss 302 GG Restoration in progress
2012 Boss 302 C Orange
1930 Ford Model A 4 Door Deluxe Town Sedan
Offline BHStang
Re: 1970 Turn Signal Housings Plating?
« Reply #1 on: March 16, 2023, 11:41:41 AM »
They should be silver zinc in 70.  Thanks to Marcus Anghel there is a good article on them in the 1970 library.
1970 Mach 1
H Code 351C 2v
DAP June 10, 1970
4 Speed Close
AC, PS, Power disk, Shaker, Rear Spoiler
Offline rcgt350
« Reply #2 on: March 17, 2023, 12:01:12 PM »
I found the answer last night, forgot that I had the cars  original housings tucked away, so I got them out and cleaned a small area off of each one, Dichromate finish appeared, and in addition the wiring harnesses are the exposed 2) wire versions.
1967 GT 350 W White
Offline BHStang
« Reply #3 on: March 19, 2023, 08:20:43 PM »
Did you take a look at the article in the library?  The socket was dichromate but the body should be silver/clear.  69s had the dichromate.  Marcus has access to a lot of original parts and I myself went through 5 sets to get a good pair to have plated.  They all showed as silver/clear.  Apparently Ford did at one point sell a 69 housing with a 2 wire connector as a mistake.
1970 Mach 1
H Code 351C 2v
DAP June 10, 1970
4 Speed Close
Offline rcgt350
« Reply #4 on: March 22, 2023, 08:30:32 PM »
I?ve looked at his site lots, but my original housings are still Dichromate
1967 GT 350 W White
