Author Topic: Correct Power Steering pump  (Read 7454 times)
Offline ChrisV289
« on: October 20, 2009, 01:01:54 PM »
I'm trying to figure out what power steering pump should be mounted on my car.  It was built Oct 1964 in San Jose and has AC.  I believe there are three types of pump. The regular ford pump with the slanted neck, the regular eaton pump, and the eaton pump with reservoir mounted to the inner fender with cars that have AC.  Now I have seen the regular eaton pump mounted on cars with AC.  So that is where I am confused.  Any help would be appreciated
« Last Edit: September 09, 2015, 08:40:27 PM by carlite65 »
2009 V6 Mustang Coupe
Offline mgmradio
Re: Correct POwer Steering pump
« Reply #1 on: October 20, 2009, 03:18:22 PM »
Eaton pump with remote resivour.
Offline $64stang
« Reply #2 on: October 21, 2009, 11:32:21 AM »
The regular Eaton Pump  can be used with Air Condition. I have seen two on a August 64' car and a April 65' Unrestored cars.
A special mounting bracket is used and the Eaton pump sits very low.
Rodes Restoration, up in Ohio ,is a good source for Early power steering stuff.
Sorry I do not have a link.
Jake
Offline 5F09CNot4Sale
  • If it does not fit, you need a bigger hammer!
« Reply #3 on: November 02, 2009, 08:26:41 PM »
Here is the set up from my Sept 28 64 Dearborn Fastback. It has AC and an Eaton Pump with resivour. This is the set up that $64stang is refering to I believe.
« Last Edit: November 02, 2009, 08:28:25 PM by 5F09CNot4Sale »
5F09C3031XX Sept 28 64 Dearborn
5F07F1838XX June 29 64 Dearborn
« Reply #4 on: November 02, 2009, 11:31:23 PM »
That sure looks like a 67-8 power steering bracket!
« Reply #5 on: November 03, 2009, 12:14:36 AM »
Just looked at Bob Mannels book, yep it does look like a 67 on page 7k6 A and 7k8 A . HOWEVER check out Page 5k24 picture F. Anoter Good picute on Page 5k25 B This pump was taken off a Late August 64 unrestored car that a guy was turning into a restomod in LA. Many Ford used the same part?
« Last Edit: November 03, 2009, 12:22:52 AM by 5F09CNot4Sale »
« Reply #6 on: November 03, 2009, 09:17:20 AM »
Wish we knew more about that system and too bad the picture of the engine in Mannel's book with that setup is not from a Mustang.
Offline Ogresko
  • 1965 C Code Honey Gold Fastback (modified)
« Reply #7 on: September 05, 2014, 12:08:38 AM »
Thought I would ask a question on this old post. I have a Jan 65 Dearborn Fastback with the Eaton pump and looking at the picture of the reservoir and pump should one paint it bare metal color or leave it unfinished and cleared. I always thought they were painted Silver
Offline $64stang
« Reply #8 on: September 28, 2014, 11:48:30 PM »
Silver paint on the reservoir natural on the bolt and washer,
The large bolt down on the pump leave it unpainted think it is like a
One inch size or bigger.
God Bless,
Jake
Offline Ogresko
« Reply #9 on: September 09, 2015, 08:36:04 PM »
Type a or type f auto trans fluid in the Eaton ps pump?
« Reply #10 on: September 09, 2015, 08:40:08 PM »
type F will do nicely.
Offline ChrisV289
Re: Correct Power Steering pump
« Reply #11 on: February 08, 2017, 12:54:38 AM »
Sorry to revive an old topic again.  Jim and/or 5F09CNot4Sale, are you able to provide the part numbers to the bolts and nuts that mount the brackets to the pump on this setup.  I looked through the excel hardware spreadsheet and searching AMK and nothing came up...
