Author Topic: HIPO distributor with no stampings  (Read 1017 times)
Offline Hipo giddyup
« on: March 09, 2023, 05:12:29 PM »
 Recently bought an Autolite HIPO dual point distributor but it  has no date code or stampings other than the 12127 on it? There is nothing stamped on the shaft of the housing either, like the C5OF. I assume it is an over the counter replacement, but is this normal??
Re: HIPO distributor with no stampings
« Reply #1 on: March 09, 2023, 05:14:31 PM »
Here is a pic
« Reply #2 on: March 09, 2023, 05:57:36 PM »
It is not typical but I have had a few.The ones I had were blank for the prefix and the date info. I have had at least one NOS one that was like that for a BB duel point. I don't know if it is only service parts or not because the others that I have had were used so I can't tell if they started life as service parts or not.
« Reply #3 on: March 09, 2023, 10:09:33 PM »
I have a Motorcraft distributor like that. No numbers except for the 12127.
Offline JohnSlack
« Reply #4 on: March 10, 2023, 09:55:38 PM »
That is really common on Motorcraft housings.
9F02G217159 1969 1/2 Dearborn BOSS 302 built July 10, 1969 1 day behind
Calypso Coral 2A 61 DSO V 3.91 Trac-Lok 6 Close ratio Retail Bob Brock Ford
0F02G106990 1970 Dearborn BOSS 302 built September 23, 1969 13 days behind
Lime Metallic EG 71 DSO S 3.50 Trac-Lok 5 Wide ratio Stock John E. Noyes Ford
« Reply #5 on: March 14, 2023, 09:44:16 AM »
Thanks everyone. Appreciate the replies!
