Author Topic: Rear end and differential seat paint - Dearborn 6 Cylinder  (Read 514 times)
Offline Danymichy
  • '70 Dearborn 250 1V
« on: March 08, 2023, 04:24:48 PM »
Hello everyone, today a new question....
I am rebuilding the rear axle of my 70 Dearborn 250 1V, I have seen in many photos that the color of the rear axle, (mine is an 8 inch with LSD), is semi gloss black, but the diff housing color is oxide red or black??
I don't remember where, but I thought I read that red oxide was only for 8 cylinders.
What is the original color?
« Last Edit: March 08, 2023, 08:31:52 PM by J_Speegle »
Re: Rear end and differential seat paint - Dearborn 6 Cylinder
« Reply #1 on: March 08, 2023, 08:31:30 PM »
Since you have an 8" rearend in 70 it would have the same finishes as an 8" for any other engine that year so same finishes. Semi-gloss black for backing plates and housing (with the bare surfaces masked off - ends and where the third member attaches) and a third member, diff housing and pinion retainer painted a red oxide primer sealer (not flat red oxide) prior to machining.
Offline Danymichy
« Reply #2 on: March 12, 2023, 06:53:23 PM »
Thanks again for your answers :D
