Author Topic: 1968 Mustang Front Turn Signal Light (correct lamp socket)  (Read 2368 times)
Offline Craners
« on: March 01, 2023, 07:51:05 AM »
Looking for help to confirm what was typical for a NJ production build. (late summer if this matters)
I believe the ?correct? original lamp socket type has the external ground tab.
The ground wire is terminated to this tab, then shrink tubing applied.
(This is what I have on my car, I believe these lamp assys are original to the car. (castings have the appropriate markings)
Any assistance is appreciated.
Thank you
Fran
Offline TLea
Re: 1968 Mustang Front Turn Signal Light (correct lamp socket)
« Reply #1 on: March 01, 2023, 08:44:17 PM »
Yes Fran they have an individual ground wire that has a ring terminal that goes around the base of the socket. Also, all three wires are formed as a ribbon so they are attached to each other.
Offline Craners
« Reply #2 on: March 01, 2023, 08:55:02 PM »
Yes, perfect match to what you described.  Thks
- your expert comments are greatly appreciated.
