Author Topic: old coil  (Read 1517 times)
Offline big bad blue
old coil
« on: February 27, 2023, 09:24:05 PM »
 Could an original coil off my 70 Cougar be considered reliable? I bought a new one from Deadnutson, but when I removed the old one from the holder I found the script and date were facing down, with a little work I think i could clean this up. Do they deteriorate with age? The engine it came off of was very low miles. thanks
70 Eliminator, dearborn 428 CJ born 11/12/69, auto.
Re: old coil
« Reply #1 on: February 27, 2023, 10:23:18 PM »
It has been my experience that old yellow top coils typically still work more times then not when tested. Of course you can easily test on a established running car when you swap it out to see if it works and runs the engine. When they fail it typically isn't marginal they simply are dead. There is a illustration and word description of how to test a coil with test equipment in the shop manual.
« Last Edit: February 27, 2023, 10:28:07 PM by Bob Gaines »
Re: old coil
« Reply #2 on: February 27, 2023, 10:31:05 PM »
From a identification stand point it has been my experience that the repro coils do not have the 2 digit number and letter code (not a date code) in between the terminals like the genuine coils have .
Re: old coil
« Reply #3 on: February 28, 2023, 12:09:09 AM »
I've never used a reproduction. Originals, as Bob mentioned, if they work refinish it and reuse it unless it's damaged.  For long trips most will carry a small box of items that could fail and leave you stranded.
