Author Topic: 67 San Jose Running Change Thread - Drivers Side Fresh Ait Vent  (Read 1240 times)
This thread is focused on when the change over took place between the earlier steel style of the drivers side fresh air vent to the later plastic style at San Jose in 1967. If you have an original car and vent please submit the car and finding (as to which style) along with the projected or real build date and identify which date your providing.
Will use this first post to collect and share what is uncovered as well as a picture of the two versions to help you identify what you find.
A modified picture of the picture member Paperback Writer posted in the thread listed below showing both styles . Thanks
From the other thread I collected
- Sept 22 early metal style
- Oct 14  early metal style
-Nov 2 later plastic style
-Dec 20 later plastic style.
Adding in the examples I found it appears that the change took place between October 14th and 29th 1966
Could still use findings to support or add to this conclusion
An earlier thread that really wasn't plant specific though all respondents were from San Jose. For reference it it linked below
https://www.concoursmustang.com/forum/index.php?topic=11024.new#new
« Last Edit: February 23, 2023, 06:15:44 PM by J_Speegle »
Offline Deuce
Re: 67 San Jose Running Change Thread - Drivers Side Fresh Ait Vent
« Reply #1 on: February 24, 2023, 10:11:29 AM »
67 San Jose signature car:
- Later Style air vent
- Actual build 11/30/66
Deuce
