Author Topic: 67 calipers  (Read 704 times)
Offline Ashley
67 calipers
« on: February 20, 2023, 08:09:20 AM »
How to identify 1967 S code calipers? Is there a difference in fluid hose for 390 cars. Keep seeing info that 390 cars had a 3/8'' hose versus 5/16'' for other engines. Seller has set that has 71016 on casting, difficult to tell if last digit is a 6 or 8, thread diameter of hose that threads into caliper is .043''. thanks
Offline Ashley
Re: 67 calipers
« Reply #1 on: February 20, 2023, 08:14:26 AM »
Correction on 67 calipers post, hose threaded diameter into caliper is .430''
Offline Shawn
Re: 67 calipers
« Reply #2 on: February 20, 2023, 10:39:43 AM »
Don't think there was a difference in 67 calipers.  All cars received the same unit regardless of engine size.  There was a difference in hose size between the 65/66 cars vs the 67 KH Calipers.  Just make sure you're getting 67 units with 7/16" inlet.  If you want a properly restored set call Shelby Parts and Restoration or Chockostang.
Shawn
Re: 67 calipers
« Reply #3 on: February 20, 2023, 07:03:52 PM »
Actually it as a early late 67 thing and not big block vs small block or even only one way in 67 thing. The earliest  67's used the same smaller size hose fitting as the 65/66 . It was not long after 67 production started that the caliper hose fitting evolved to the larger size. Those cars built in early Dec 66 or earlier are in the gray area IMO even though it is after the MPC change over date.
« Last Edit: February 20, 2023, 09:09:12 PM by Bob Gaines »
Re: 67 calipers
« Reply #4 on: February 20, 2023, 08:13:25 PM »
Using the search feature and "67 caliper" you can find a fair number of threads with pictures and details
https://www.concoursmustang.com/forum/index.php?topic=8827.0
https://www.concoursmustang.com/forum/index.php?topic=8827.msg138009#msg138009
https://www.concoursmustang.com/forum/index.php?topic=27370.msg167598#msg167598
Will merge this post with one of the above
