Author Topic: Engine Code  (Read 2167 times)
Offline 68 S Code
Engine Code
« on: April 15, 2011, 06:28:34 PM »
I'm trying to order a set of ECS decals and they asked me a question on the car that I couldn't answer so I figured someone here would know or help me with s link where I could find it. They are asking me the engine code. It's not the S in the VIN but the code at the top left of the build sheet. Well I never found the build sheet. It's a 68 S code vert with s C6. I figured there is only one code. Something like 322? I know I either saw something on a web site, Holley carb book, Ford HP engine guide? Anyone know where I should look?
Re: Engine Code
« Reply #1 on: April 15, 2011, 07:58:30 PM »
do you still have the metal tag on the intake? if so the code will be there too.
Offline 68 S Code
Re: Engine Code
« Reply #2 on: April 15, 2011, 09:44:00 PM »
Regretfully I don't have the original.
Re: Engine Code
« Reply #3 on: April 15, 2011, 11:01:02 PM »
405J05 for an automatic 68 390 would be my guess ;)
Re: Engine Code
« Reply #4 on: April 15, 2011, 11:05:05 PM »
Mustang Restoration Guide by Corcoran and Davis, pg 134, lists 5 different engine codes.  The criteria: number of cylinders. CID, Carb and data code.       Build date,  C-6 trans and body style are not referenced.  For a 8 cylinder, 390 GT, Ford 4v with data code S the number goes from 318 through 322. Hope that helps.  Brian
Offline 68 S Code
Re: Engine Code
« Reply #5 on: April 16, 2011, 02:35:57 AM »
Thanks for those of you who chimed in. Dug out the engine tag. Always thought it was wrong but it reads as follows;
390. 68. 10. (ford)
8F.  K.  319. J
Build date of car 7-12-68
Offline TLea
Re: Engine Code
« Reply #6 on: April 16, 2011, 06:10:49 PM »
Think thats the 428 PI auto
Re: Engine Code
« Reply #7 on: April 16, 2011, 07:36:54 PM »
Thanks Tim -
Offline 68 S Code
Re: Engine Code
« Reply #8 on: April 17, 2011, 12:37:25 AM »
If I gave ESC the 319 J code off the tag would that be enough for them? I guess I thought the engine tag was wrong all this time but i think its good, isn't it?
