Author Topic: 64.5 Seat Belt Question  (Read 698 times)
Offline Countrysquire
    • Houston Vapor Blasting
« on: February 12, 2023, 09:47:08 PM »
Should the clasp on the belt and the eye bolt that it connects to that screws into the floor both be clear zinc plated?
Bobby Crumpley
MCA#20316
www.houstonvaporblasting.com/
64.5 Dearborn Coupe
5F07D173***
65A M 86 20F 62 1 5
Re: 64.5 Seat Belt Question
« Reply #1 on: February 12, 2023, 11:31:04 PM »
Looks like that would work. Never tested them to see what exactly the original finish was. If too bright or shinny easy enough to dull them down
Some originals
« Reply #2 on: February 13, 2023, 12:21:39 AM »
Thanks Jeff. Once I pull them and remove the dull grey residue I will test to see if they react to phosphoric acid the way zinc normally does.
« Last Edit: February 13, 2023, 09:45:51 AM by Countrysquire »
Bobby Crumpley
MCA#20316
64.5 Dearborn Coupe
5F07D173***
65A M 86 20F 62 1 5
« Reply #3 on: February 13, 2023, 12:44:53 AM »
Soak them in evaporust, parts that are cad plated will come out yellowish color/chalky.
