Author Topic: 1970 Lower Steering Column Trim Panel Mounting  (Read 1940 times)
Offline sah62
« on: February 11, 2023, 01:54:01 PM »
I've never quite understood how to properly mount the plastic trim panel shown in the attached picture. There are two screws that secure it at the lower edges, but what, if anything, keeps it in place where the upper end meets the steering column (and I have a big gap)? What's the function of the small spring clip (you can see one just to the right of the headlamp switch) on each side?
Scott Hollenbeck
2019 Lincoln MKZ 3.0T AWD
2003 Mercury Marauder 300A
(more non-Ford stuff)
Offline alanmac
Re: 1970 Lower Steering Column Trim Panel Mounting
« Reply #1 on: February 11, 2023, 08:03:58 PM »
Insert the top front edge under the corresponding bottom edge of the trim above it then rotate the back up and screw it in.  A tricky attachment feature!
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
Build Date: October 7, 1969
0T1190xx
« Reply #2 on: February 11, 2023, 10:53:45 PM »
As mentioned above those clips were designed to "grab" and align the upper edge to the gauge bezel.
There are a few things to check that if off can create gaps or issues
Is there the correct number of spacer/aluminum blocks between the brake and clutch bracket and the steering column clamp?
Do you have the correct lower steering column trim panel for your application? There are two depending on body type. Coupe and convertible is one while the sportroof/fastback uses a different one if I recall correctly (at least I recall in 69 they were  ::). Don't have an illustration handy at the moment
« Last Edit: February 11, 2023, 10:56:13 PM by J_Speegle »
Offline sah62
« Reply #3 on: February 12, 2023, 10:46:09 AM »
That did the trick - thanks!
Scott Hollenbeck
Offline Badgas6228
« Reply #4 on: February 21, 2023, 12:38:55 AM »
Thanks Alanmac, Been trying to figure there clips out, they clip on to the lower facing you. And secure it to top piece?
Offline alanmac
« Reply #5 on: February 22, 2023, 08:04:59 PM »
The Two metal clips straddle the top side edges of the lower trim piece on both sides.  Per the attachment, they are positioned close to the back edge.  The springs clips hang out over the back edge so they are in interference with the dash.  The springs push / align the trim forward under the upper front edge.  I hope this is understandable.
« Last Edit: February 22, 2023, 08:10:59 PM by alanmac »
1970 Mustang Mach 1
351W Shaker Hood
Built at Metuchen
0T1190xx
Offline Badgas6228
« Reply #6 on: February 26, 2023, 11:46:16 PM »
Thanks, I will try it when I get to that part this summer, glad i found the clips last year. Thanks
Offline Badgas6228
« Reply #7 on: June 19, 2024, 02:19:47 AM »
Ok Fellows, I finally installed the cover under dash, Now I get it, you tuck that upper left side in ,those little metal clips just help center it, Screws secure the whole thing, Thanks Boss Brothers. Greg
