Author Topic: Idle increases as brakes applied  (Read 1728 times)
Offline V8_bloke_28
« on: February 07, 2023, 02:49:41 AM »
Hi people
Dads 67 mustang has developed an issue where the idle increases when the brakes are applied.
We thought it was the booster but that?s been refurbished and checked twice.
Engine is a stock 289 and has 20hg vacuum at idle.
All hoses look good and engine runs perfect without brakes on.
Any suggestions would be appreciated.
Cheers
Offline 1966KGT
Re: Idle increases as brakes applied
« Reply #1 on: February 07, 2023, 08:22:53 AM »
Have you isolated the booster by unhooking and plugging it? Just a place to start, my experience has been with vacuum leaks is high idle. Could be a leak in another area and when brakes applied puts a demand on vacuum of engine and the weak sealing area will leak? just my thoughts to start. Anyone else?
« Reply #2 on: February 07, 2023, 05:04:42 PM »
Yes sounds like a vacuum leak.
Plug off the vacuum hose from the intake will likely result in no change when the brake is pressed.
Pulling a vacuum using the check valve connection at the booster will likely be impossible or not hold a vacuum once established
Offline hopey
« Reply #3 on: February 07, 2023, 11:10:48 PM »
You say booster is good. Did you verify the check valve is holding?
1970 BOSS 302
Built 11/15/69 Dearborn
Offline V8_bloke_28
« Reply #4 on: February 08, 2023, 02:18:54 AM »
Thanks for your ideas.
Check valve  and grommet is brand new.
Dad called a mechanic over to see what he thinks and he believes it?s the booster.
Looks like it?s coming out for a 3rd time.
This time it?s gonna get thrown at someone!
Cheers
Offline Drew Pojedinec
« Reply #5 on: February 08, 2023, 11:51:43 AM »
I hear this a lot.
Me: is xyz good?
Customer: Its brand new.
Me: did you test it?
Customer: no.
Assume everything is bad and proceed accordingly.
« Reply #6 on: February 08, 2023, 12:57:30 PM »
Cheers
An SAE mechanic or the guy down the street who owns a hot rod (built by someone else)?
Replace the grommet and valve first. A lot cheaper and easier than pulling the booster.
The boosters usually leak to the inside. With the engine running push on the brake and use a section of  hose to your ear and near the push rod to see if you hear a hiss at the firewall.
« Reply #7 on: February 08, 2023, 01:54:18 PM »
Then you'll never get anything done.
Offline Countrysquire
    • Houston Vapor Blasting
« Reply #8 on: February 08, 2023, 03:45:39 PM »
I hear this a lot.
Me: is xyz good?
Customer: no.
Yep. Lost an hour of my life deciphering a electrical schematic written in German trying to figure out why the headlight bulb I just replaced on a 911 still wasn?t working. Turns out the new bulb was bad right out of the package. Poor troubleshooting on my part by assuming the new bulb was good.
Bobby Crumpley
MCA#20316
www.houstonvaporblasting.com/
64.5 Dearborn Coupe
5F07D173***
65A M 86 20F 62 1 5
« Reply #9 on: February 08, 2023, 05:14:59 PM »
My wife's 911 has a license plate that starts with AUF. It just sounds German. That's also the sound I make when I have bend down that far to get in it...
« Last Edit: February 08, 2023, 05:30:41 PM by Bossbill »
