Author Topic: Rattle Can Finish on Rear Axle Housing  (Read 1356 times)
Offline bburns31
« on: February 05, 2023, 11:59:49 PM »
Is this typical for a rattle can finish? It seems splotchy to me. I removed the existing finish down to metal. Metal prepped, primed, sanded, cleaned, tack ragged and applied 2 light coats and 1 heavy wet coat. Does it need another coat or is this as good as it's going to get for a semi gloss black 2k in a can?
66 Mustang Dearborn C Code Sauterne Gold Metallic
Re: Rattle Can Finish on Rear Axle Housing
« Reply #1 on: February 06, 2023, 09:00:27 AM »
agreed. a tip. the fill plug should be installed. the studs were not installed.
« Reply #2 on: February 06, 2023, 11:38:57 AM »
What I did on a similar-condition housing was to strip it to bare metal, dunk in rust remover such as EvapoRust or Rust-911, sanitize, 2K Black Epoxy sealer followed by 2K filler primer (masked off some areas like welds etc) sand to the black and repeated as necessary till minor pitting was gone. Shot another coat of black epoxy primer followed by a lacquer coat of semi-gloss black.
« Last Edit: February 06, 2023, 11:41:58 AM by 67gtasanjose »
Offline slk25
« Reply #3 on: March 04, 2023, 09:20:42 PM »
I agree with Carlite's tip about the plug being inserted during paint.
 Otherwise, your finished product looks as good as anything Ford produced in 1966.
January 28 1966 Dearborn manufactured hardtop 289 2v 3spd manual
