Author Topic: 1968 Mustang Left Front Marker Light Assy. quality used core for rebuild  (Read 556 times)
Offline Craners
Wanted: 1968 Mustang Light Assembly Core (used original OEM)
Front Fender Marker Light. (Left Side  (?..429A part number))
    Quality used assy that I can restore/chrome.
        - no or limited chrome pits (both outter/inner surfaces)
        -  no cable required.
        Will pay reasonable price for a quality piece.
My plan is to completely disassemble and restore.
Needed for restoration in process.
Thank you
Fran
« Last Edit: February 18, 2023, 04:30:11 PM by Craners »
Offline Craners
Re: 1968 Mustang Left Front Marker Light Assy. quality used core for rebuild
« Reply #1 on: February 18, 2023, 04:31:37 PM »
I?m still searching .
Thank you.
Fran
No longer looking.
Quality cores (no pits) can be sourced with a little perseverance and patience.
Thank you for your support.
« Last Edit: March 05, 2023, 07:54:29 AM by Craners »
Offline rustbucket
« Reply #2 on: February 19, 2023, 02:27:19 PM »
I have a pretty nice pair,
they will even clean up much better if you spend a few minutes on them.
$175 for the pair
send me a private message if interested
not sure what your working on, but have other 68 stuff as well
« Reply #3 on: February 19, 2023, 03:34:44 PM »
Thank you.
Fran
Many people buy a repro and use the body as a donor and use the restored pigtail and studs to make it look new as well as original on the backside. Once installed in the fender with the sheet metal retainer on the back side it looks OEM.  That is if you want it new looking. It is hard to do that using another used body. More power to you if can locate a marker light housing that the trim on the outside looks as good as new or good enough for concours scrutineers.
Offline Craners
« Reply #4 on: February 20, 2023, 07:33:25 PM »
Thank you for the information.
I?m reusing very good used socket and cable assys, and will be installing them in original quality pot metal housings that are being chromed.  (Quality cable assys are available. Housing assys take a little more effort to locate)
This keeps the factory markings with all quality finishes.
It?s a little more work and certainly cost, but the finished product very nice.
My goal is to use as much of the factory design parts, and restore them where possible.
« Reply #5 on: February 20, 2023, 07:55:02 PM »
I would be interested in knowing if you don't mind sharing what the going rate for rechroming the housing are as a pair or each . It has been many years since I have had to do that and have lost track on costs.
Offline DJames
This one is pretty nice. $80 plus shipping.
