Author Topic: Wanted: 67 Mustang battery tray 24F size dated month 10 or 11 or 12.  (Read 1211 times)
Offline Kyle Zammit
Hi all,
I am looking for a used good condition with no rust pitting or few 24F battery tray, dated (months) first numbers start 10 or 11 or 12
Anyone who have one send a PM Sent or Email me kylezammit123@gmail.com
Thanks Kyle.
Re: Wanted: 67 Mustang battery tray 24F size dated month 10 or 11 or 12.
« Reply #1 on: February 04, 2023, 11:55:05 AM »
If you choose to use a NOS, let me know
Offline Kyle Zammit
« Reply #2 on: February 04, 2023, 11:56:57 AM »
You have one NOS ?
If you have one what is the date code please?
« Reply #3 on: February 04, 2023, 12:04:00 PM »
You have one NOS ?
Not that date coding. I might also have a used 22F tray I might be talked out of, one with an October date coding on the brace.
With a spot-welder, a person could transfer the dated brace onto a NOS tray but of course the tray wouldn't be dated, just the (visible) brace. That's the best I could offer.
Correction: August 20 date code, removed from a Nov 2, San Jose built car
« Last Edit: February 04, 2023, 12:25:53 PM by 67gtasanjose »
« Reply #4 on: February 04, 2023, 01:52:27 PM »
For your information the earlier 67 Mustang battery trays have a multiple pattern of holes stamped into the brace. The hole pattern corresponded to the mounting bracket of a tilt vacuum can . Different hole patterns were designed to mount the vacuum can in a different orientation depending on the engine the Mustang was equipped with . The holes in the brace were on the early trays regardless of if the car had the tilt option or not. The hole patterns in the battery tray brace were eliminated in later 67 production when Ford changed locations for the vacuum canister .
Offline Kyle Zammit
« Reply #5 on: February 04, 2023, 05:01:17 PM »
Sorry but I prefer to find one 24F size. But thanks.
« Reply #6 on: February 04, 2023, 06:31:59 PM »
Here are some pictures of a tray with the holes which was taken off of a 67 Shelby and also a picture of a regular Mustang with a tilt canister bolted using the holes. I am sure that there was overlap of usage as inventory was used up.
« Reply #7 on: February 05, 2023, 08:52:11 AM »
We had a lengthy discussion about this running change of battery tray-mounted canisters and no distinction was made using stamp date codes within that thread.
Do any of your Shelby battery trays have date codes Bob?
« Reply #8 on: February 05, 2023, 11:43:16 AM »
I think you can see one on the painted tray in my picture.
Offline Kyle Zammit
« Reply #9 on: February 05, 2023, 03:48:44 PM »
Thanks for all the information Bob.
This is the Original to my 67 Shelby GT500 with the correct date codes. Car serialized 12/6/66 Releasd 12/28/66. This tray has a date code on the tray 11 10 8 and on the bracket 12 5 2D.
I need one exactly like this one with no holes in very nice condition.
I am looking for one with Similar date codes month 9 or 10 or 11 or 12.
« Reply #10 on: February 05, 2023, 06:47:47 PM »
"No holes for canister mounting" is how I interpret your request. This follows the research that I gave this topic several years ago. I tried to enhance your image a bit to better see in the shadows but I found "no holes" on your original December battery tray brace.
« Reply #11 on: February 05, 2023, 10:47:27 PM »
I certainly haven't seen them all but just reporting on what I have seen that in particular seems to be most typical based on my 67 Shelby observations. Date codes on trays are helpful given it is very common for battery trays to have been changed because of corrosion and restoration and service trays don't have the holes.
Offline Kyle Zammit
« Reply #12 on: April 10, 2023, 05:16:41 PM »
Still looking for one.
« Reply #13 on: April 11, 2023, 09:07:30 AM »
It is very unlikely that you will find a assembly line with the correct date codes and no corrosion. All of the originals that I have see have a unacceptable amount of corrosion. It would be best to do as suggested above and move the build dated into a NOS part.
Offline 21.04
« Reply #14 on: April 11, 2023, 12:20:45 PM »
Kyle, another suggestion might be to have the holes welded and ground smooth on the tray you have?
66 K code Conv GT red/red deluxe 4 spd
66 A code Conv Non-GT black/red deluxe 3 spd
66 Sprint Conv Unrestored Green/blk std 3 spd
