Author Topic: Help Identify Differntial  (Read 1031 times)
Offline bburns31
« on: January 31, 2023, 12:18:17 PM »
I am ordering a rebuild kit and want to make sure I have the correct kit. Looking through the library docs, I'm not positive which model I have since mine doesn't have the bump stop on top of the carrier.
My tag indicates WCZ-E is a 2.8 ratio 7 3/4" ring gear dia. Non-locking 28 axle shaft spline
Looking at the rebuild kit options, I'm assuming I go with a 8" kit? The kit I was looking at mentioned a 25 pinion spline count which made me unsure.
Any reassurance you could provide would be me helpful as I'm wading into unknown waters. Is the library doc I've attached correct?
66 Mustang Dearborn C Code Sauterne Gold Metallic
Offline JohnB
  • 0F03R120303
Offline bburns31
Re: Help Identify Differntial
« Reply #2 on: January 31, 2023, 12:38:31 PM »
https://www.fordification.com/tech/rearends_ford02.htm
Thanks, John. That is the site I used to identify my model. The 7 3/4" threw me for a loop. Is that considered an 8" diff? I don't see any kits for a 7 3/4".
