First welcome to the site. Hope you find the support and information helpful in your restoration.
Guess your asking about paint marks. Is that correct.
Standard Consideration: Paint marks should be the last concern in a restoration after you have made sure your parts are exactly like originals or originals, finished correctly with all the right hardware and details. Paint marks do not "make up" for installing poor reproduction parts or non-factory finishes instead they will draw the eye to these defects and poor choices. Very few judging venues require paint marks so in most cases not required but incorrect markings in those same classes that don't require them do open and owner to deductions if they are incorrect for the car and application. Positive thing is that many of the marks can be applied later if your unsure or looking for confirmation, have a concern that maybe one or more you see might not be correct for you. With that said we progress.
Will need more information about your car than what you have provided
Will need
- transmission type,
- when the car was completed,
- AC and or PS?
- Rear spring engineering numbers will reduce the need to guess at those markings
Think that will do it for your first posting and question here. Again welcome
