Author Topic: 4-spd Toploader Hurst shifter linkage bushings  (Read 3619 times)
Offline K-HESS
Re: 4-spd Toploader Hurst shifter linkage bushings
« Reply #15 on: February 01, 2023, 03:38:38 PM »
Here is one thats from a small block. Only the mounting bracket and reverse rod are different on the bog block. Mounting brackets are available in reproduction not sure about the reverse rod. This one is about as cheap as you will find posted on the internet for sale.
« Reply #16 on: February 01, 2023, 07:28:06 PM »
FYI  Jay Cushman is a well known parts vendor specializing in ford performance parts that has been around for decades.
Offline Angela
« Reply #17 on: February 03, 2023, 09:25:04 AM »
Thank you! I will give Jay a call today.
Offline Angela
« Reply #18 on: February 12, 2023, 09:50:02 AM »
Thanks again for everyone's help. I picked up the parts (above) from Jay.
I now need to locate D0ZA-7B112-D and a 0ZR-03C bracket.
Admittedly being unfamiliar with these parts, can anyone recommend their favorite resource for disassembly and rebuilding of these shifter mechanisms? I see that Holley has a rebuild document for the aftermarket Hurst shifter assy., but thus far I haven't seen a similar document published for the Ford OEM parts.
Thanks!
Offline 70-Conv_4sp
« Reply #19 on: February 14, 2023, 12:47:10 AM »
Go to this website, they are an authorized rebuild-er for OEM hurst shifters
https://www.shifterdoc.com/HurstRebuildForm.pdf
70-Conv_4sp (Cougar, XR7}
Offline 70-Conv_4sp
« Reply #20 on: February 14, 2023, 10:54:07 PM »
Also - This is a company that reproduces many factory transmission shifter mechanism, both Automatic and manual etc...,
just in case no one has mentioned them before.
https://www.kickdownrods.com/
70-Conv_4sp
