Author Topic: 428 CJ Fan Shroud Restoration  (Read 1037 times)
Offline 69gtconv
« on: January 20, 2023, 06:54:59 PM »
I have an old 428 CJ Fan Shroud that came with my '69 Q-Code Convertible that is in need of restoration; it is discolored, stiff and dirty (pics below) .... any tips on how best to restore this shroud? Thanks in advance.
1966 T-Code Coupe (1st Car, Sold)
1967 GT 350 4-Speed w/original Paxton SC (Sold)
1970 Boss 302, 4-Speed (Sold)
1969 GT S-Code Convertible, Automatic (sold)
1969 Cougar XR7 R-Code Convertible, 4-Speed (sold)
1969 Mach 1 R- Code, 4-Speed (being restored)
1969 GT Q-Code Convertible (to be restored)
Offline preaction
Re: 428 CJ Fan Shroud Restoration
« Reply #1 on: January 21, 2023, 11:47:04 AM »
Your shroud seems to be mostly dirty from road dust and dirt you could try using walnut shell blast media on a small portion on the backside at low air pressure to try and clean the surface. A product like simple green and brush may work as well.
« Reply #2 on: January 21, 2023, 05:42:32 PM »
Might want to test an unseen area, once installed, before you blast. Think even walnut shells might be too aggressive but I haven't try them for this purpose. Just out of caution
Thing a good careful, these things can be delicate, scrubbing a number of times will do wonders to start with.
Offline Countrysquire
    • Houston Vapor Blasting
« Reply #3 on: January 21, 2023, 10:57:54 PM »
We vapor blasted then sprayed with a matte clear coat on our ?70 Bronco fan shroud and we?re pleased with the results. Dry ice blasting would likely work well also. You might want to check and see if someone in your area does either type of blasting and understands how rare and delicate that piece is. I certainly wouldn?t risk shipping it anywhere.
Bobby Crumpley
MCA#20316
www.houstonvaporblasting.com/
64.5 Dearborn Coupe
5F07D173***
65A M 86 20F 62 1 5
