Author Topic: Weatherstrip Adhesive Removal  (Read 3159 times)
Offline Craners
« on: January 11, 2023, 08:35:56 PM »
Searching for advice on how to remove weatherstrip adhesive from an original deck (trunk) lid seal.
I was able to remove the original weatherstrip seal from a 1968 Shelby fiberglass deck lid without damaging the rubber seal. The seal is actually in excellent, very soft condition .
I?d like to remove all the glue from the seal? to prep the seal for installation, once the paint work is completed.
Is the 3M product the way to go, or are there other methods that don?t risk damaging the rubber seal?
Experienced Comments appreciated.
Thank you
Fran
« Last Edit: January 11, 2023, 08:39:04 PM by Craners »
Offline lightwtjet
Re: Weatherstrip Adhesive Removal
« Reply #1 on: March 29, 2024, 09:50:27 PM »
I found that common paint thinner will cause the original (1968) weather strip to almost dissolve at the interface with the adhesive. That separates the two but would ruin the weatherstrip.
« Last Edit: March 30, 2024, 05:58:04 PM by lightwtjet »
1968 CJ - Owner and paint original. Dec 67 build in Dearborn. One of 50 135 Cobra Jets. Ford engineering used it for 8 mos. to resolve problems in the 50 early car build. Ford by-passed the normal sign off to get cars to the Winternationals drag race.
« Reply #2 on: March 30, 2024, 12:10:32 AM »
I would use MEK or MEK substitute.
Offline Munypit
« Reply #3 on: April 15, 2024, 02:56:24 PM »
I've had good luck with charcoal lighter fluid and it doesn't hurt the paint.
69 Mach 1 351W with A/C FMX built 11/68 at Metuchen
« Reply #4 on: April 15, 2024, 08:05:59 PM »
There are also "things" you should NOT used or be aware of their shortcomings: any acetone based product like "Goof-Off"; Krud-Kutter (it MUST be wiped off in under a minute to prevent the paint from being destroyed); regular paint thinner, also a "timed" use product.
« Reply #5 on: April 15, 2024, 11:03:39 PM »
[/quote
Well he is talking about the seal so no paint is involved.
