Author Topic: Correct 1966 SJ 6 cylinder PS control valve finish.  (Read 1448 times)
Offline dsielke
« on: January 01, 2023, 04:32:51 PM »
I am in the process of restoring the PS linkage and control valve on my Dec. 1, 1965 San Jose convertible. I was under the assumption the mounting / stud housing was originally natural steel but after disassembly it appears to be originally painted black. Is this correct?
6R09A138419: 1966 GT Fastback, Springtime Yellow
6R08T138429: 1966 Convertible, Tahoe Turquoise
Re: Correct 1966 SJ 6 cylinder PS control valve finish.
« Reply #1 on: January 02, 2023, 05:33:44 PM »
Originally and in add on kits provided to the dealerships these parts were not paint but like V8 units bare steel finish matching their making. Cast steel, formed steel, aluminum and so on
Think someone painted your assembly
Offline dsielke
« Reply #2 on: January 02, 2023, 05:38:49 PM »
Interesting. They must have gone through a lot of trouble a long time ago. It was painted against clean metal under the clamp and boot that appeared to be original.
« Reply #3 on: January 02, 2023, 06:04:07 PM »
Show us the clamp, if you could.
« Reply #4 on: January 02, 2023, 06:04:49 PM »
It might have been rebuilt at some point or a service piece from later that 66
Think I have pictures of three kits all early ones with the blue and white labels and the finishes are the same. Could look for unrestored car examples but believe I will find the same
« Reply #5 on: January 02, 2023, 07:24:58 PM »
I asked about the clamp because a lot of later rebuilds sport a much different clamp than assy line.
Offline dsielke
« Reply #6 on: January 02, 2023, 10:04:11 PM »
This is a picture I took this afternoon after cleaning, blueing and replacing marks. I will take a better pic of the clamp as soon as I can. It has a tab that keeps it aligned with the stud housing. I don?t think it is a replacement. The housing is still soaking in the evaporust tonight.
Offline dsielke
« Reply #7 on: January 02, 2023, 10:37:55 PM »
Round tab on top fits perfectly into slot. Pretty sure it was made for it.
Offline dsielke
« Reply #8 on: January 02, 2023, 10:39:15 PM »
Another question, did the 200 PS have a strap / pinch clamp to hold the hoses against the center link like V8s?
« Reply #9 on: January 03, 2023, 10:35:03 AM »
Sorry, I wasn't clear. During rebuilds the boot clamp often gets replaced. The two screws also get replaced with sharp tipped replacements, rather than the blunt nose originals.
Also, the large, yellow, plastic gasket on the valve gets replaced with another color.
Offline dsielke
« Reply #10 on: January 03, 2023, 02:28:21 PM »
Ah, this was the clamp and screws.
« Reply #11 on: January 03, 2023, 04:00:14 PM »
I can't see the side I need.
Although a different year and application, the boot clamp detail applies.
https://www.concoursmustang.com/forum/index.php?topic=26983.msg165810#msg165810
Your screws are correct and difficult to find.
Offline dsielke
« Reply #12 on: January 03, 2023, 04:27:02 PM »
Thanks, good to know. I will be sure to clean and reuse them. If you are talking about the round cutout on only one side it does have it
« Last Edit: January 03, 2023, 05:59:22 PM by dsielke »
Offline dsielke
« Reply #13 on: January 03, 2023, 06:08:22 PM »
Wow! I just compared the clamp to the one that came with the new stud rubber boot. Not even close to the same.
Offline dsielke
« Reply #14 on: January 03, 2023, 09:33:11 PM »
I was asked about the markings on the center link. It may be hard to see in this image but the yellow and white stripes were found during cleaning. The linkages were painted black at some point which protected them a bit I think.
