Author Topic: spring color for C6 "H" servo  (Read 1425 times)
Offline 67gt390fb
« on: December 29, 2022, 01:12:14 AM »
Trying to get a C6 transmission set up for my mustang.
I have 3 springs I could use in an H code servo I picked up (it was missing the spring).   I have a yellow one, a plain one and a blue one.
Could one of these be correct spring to match the "H" intermediate servo?
If not, what should i be looking for?
7R02S153xxx      12/15/66
Offline Keith Stem
Re: spring color for C6 "H" servo
« Reply #1 on: December 29, 2022, 08:53:51 AM »
If I am reading the MPAC correctly Section A70.5 page 4 and 6, two springs (P/N 70D28) are possible.
The first spring (#28) is for a 1967 390 GT after 1/4/67 and it is 2.66 inches with 9.5 coils. This spring is also used for a 1968 390 GT and the 428. No color was listed.
The second coil (#29) is for a 1967 390 GT before 1/4/67, and 2.39 inches with 8 coils and is yellow.
« Reply #2 on: December 29, 2022, 10:47:07 AM »
That's what I see as well in the 1968 MPC.  Pictures included so that you can see all of the information.
« Reply #3 on: December 29, 2022, 10:49:11 AM »
Regarding the "H" code, from the previous pictures from the MPC, it looks like the "PGB-H, H1" was used on the full size Ford (A), Fairlane (B), and Thunderbird (S) depending on the year.  I don't see any Mustang application.  Note that this is in regards to the "transmission model" and may not equate to the servo identification.  Just pointing it out.
« Reply #4 on: December 29, 2022, 11:22:23 AM »
H servo was used on 67 and early 68 GT 500 Shelby application.
Offline Keith Stem
« Reply #5 on: December 29, 2022, 03:15:38 PM »
If the transmission is a PGB-H the (#29) spring is the correct spring at 2.39 inches with 8 coils and is yellow.
« Reply #6 on: December 29, 2022, 07:29:47 PM »
Thanks Bob
Offline 67gt390fb
« Reply #7 on: December 29, 2022, 11:53:26 PM »
according to my build date of 12-15-66 , the PGA-P would be the O.E. trans  ,  using the # 29 yellow spring.
thanks,  this is great to find this info!  I spent a LOT of time searching.    I will measure the springs pictured and post results tomorrow. am curious to see if the yellow and plain one match the info for 28 and 29.
« Last Edit: December 30, 2022, 12:11:31 AM by 67gt390fb »
Offline 67gt390fb
« Reply #8 on: December 31, 2022, 07:00:24 PM »
the color codes do not match up, but the center one pictured in first post is close to specs for #29
measurements came out as:
first :       1.89"  and 6-3/4 coils       not close to any listed here
second:   2.29" and 8-3/8 coils        close to #29 specs(will use this one)
third:       2.53" and 8-7/8 coils        close to # 28 specs
