Gentlemen, one final attempt to summarize what I am hearing and what I am frustrated with. I will try to keep this short and concise:
(1) Charles, I was wrong, the assembly manual specifies C7ZB #'s (not C7ZZ). The 67 assembly manual indicates the C-shaped seal with the following PNs
a) C7ZB-6543720 for body type 65,76 (coupe, convert)
b) C7ZB-6343720 for body type 63 (fastback)
(2) Pete and others are asserting that ALL 67-68 mustangs, regardless of body type used the C-shaped seal (NO trapezoidal seal was used for 67-68).
(3) THE PROBLEM: in contrast to statement #2, above, I cannot find a single vendor, including Daniel Carpenter, selling a C-shaped seal for a 67 fastback.
3a) Why would Carpenter and other vendors produce the trap-shaped seal for 67-68 fastback if it was never used for 67 fastback?
3b) Where are you guys purchasing your C-shaped seals for 67 fastback? I have called six suppliers including NPD and Mansfield and none carry the
C-shaped deck lid seal for 67 fastback. They all state the trap-shaped seal is correct and is what they carry.
