Author Topic: 1968 Front Disc Brake Pad, Metal Retaining Brackets  (Read 3129 times)
Offline Craners
« on: December 26, 2022, 11:32:02 AM »
Searching for correct bracket form/stamping and plating for factory correct for C8?.version design.
When searching for brackets, there is little to no detail shown to compare to my originals.
Has anyone found a decent replacement the original?
Any suggestions is appreciated.
Thank you.
Fran
Re: 1968 Front Disc Brake Pad, Metal Retaining Brackets
« Reply #1 on: December 26, 2022, 01:37:50 PM »
Thank you
Fran
I am hoping you are referring to the spring steel clip that holds the pads in. If you are then you are in luck because they are commonly included in the various brake hardware kits with the the rubber pin boots and are typically like the assemblyline. Bare steel or a light PO is the typical finish.
« Reply #2 on: December 26, 2022, 01:55:50 PM »
Perhaps you can identify the "bracket" by referencing the Ford basic part number based on the attached diagram.  That should remove any doubt as to what you are referring to.
Offline Craners
« Reply #3 on: December 26, 2022, 02:25:30 PM »
I believe the Ford Part Number for the bracket is  C8OZ 2B295-
From my searching, this is used one a couple of Ford cars.
Sorry for the confusion.
See photo attached..
Offline Anghelrestorations
    • Anghel Restorations
« Reply #4 on: December 26, 2022, 02:40:55 PM »
For that bracket the originals were galvanized.  They also had a Ford trademark stamp on them with no other marks or engineering numbers.
If you are looking for that they make reproductions without any Ford stamping or originals (used or NOS).  Should not be a hard part to find.
Marcus Anghel
www.anghelrestorations.com
Offline preaction
« Reply #6 on: December 26, 2022, 03:05:53 PM »
Don't lose track of the fact that these parts are actually a spring and do need replacement as a consumable part depending on how the car is used. There are service brake hardware kits out there D0OZ-2C077-A
« Reply #7 on: December 26, 2022, 06:02:38 PM »
Just for clarification ,the pad retainers are springs but the part that the OP identified he was talking about is not a spring but simply a metal cover.
« Reply #8 on: December 28, 2022, 03:26:26 PM »
Just for reference adding a photo of the piece I was talking about.  Also shows the original galvanized finish.  One of the few parts on Mustangs that was galvanized as it was unusual as a finish and about impossible to get redone today.
20221227_115224 by Marcus Anghel, on Flickr
20221227_115304 by Marcus Anghel, on Flickr
Marcus Anghel
« Reply #9 on: December 28, 2022, 05:43:43 PM »
Wasn't there also a later service replacement shield marked with Ford or FOMOCO in the oval in script?
Offline preaction
« Reply #10 on: December 28, 2022, 07:34:34 PM »
The D0OZ hardware kit  has it as FoMoCo in script inside of an oval.
« Reply #11 on: December 29, 2022, 01:59:18 AM »
The FoMoCo oval is the most common one I ever see both on original and service replacements.  This is the only set I have ever come across that is the square FoMoCo so I kept them on my shelf.  And also as a reference for the correct finish.
Marcus Anghel
« Reply #12 on: December 29, 2022, 04:57:15 PM »
Thanks Marcus never ran across the FoMoCo rectangle but if it was used on service replacements in the 70-plus that might be one reason
