Author Topic: Prepping quarter panel trim  (Read 731 times)
Offline 68 GT
« on: December 06, 2022, 04:43:16 AM »
How do you prep a coupes quarter panel trim for paint? If you sand it, that will remove any texture they have. Seems like sandblasting might be too harsh. My 67?s have light rust on them.
VIN 7T01C246XXX
Actual build date 5-11-67
VIN 8F01J208XXX
Actual build date 6-27-68
Re: Prepping quarter panel trim
« Reply #1 on: December 06, 2022, 09:21:42 AM »
I would use lacquer thinner and a scotch bright to remove the paint then remove the rust with chrome wheel cleaner.
« Reply #2 on: December 07, 2022, 05:40:27 PM »
Strip to bare metal to maximize the grain. Often helps to scrub using circular patterns.
If you use a primer at all it can't be a high fill one (wouldn't use one myself but that is me)  and light coats of color until you get cull coverage. Again to keep as much visible grain in the final prodccue
Offline 68 GT
« Reply #3 on: December 07, 2022, 09:38:41 PM »
Thanks for the tips!!
VIN 7T01C246XXX
VIN 8F01J208XXX
