Author Topic: Grommets for '65 Fastback Trunk Lid  (Read 2356 times)
Offline MWM
« on: April 04, 2011, 05:21:29 PM »
Hello:
I have a 1965 Mustang Fastback which is currently in the paint shop.  I noticed that there are white plastic grommets where the torsion bar goes through the trunk hinge.  Any idea where I can get a set?  I have tried several shops.
thank you!
Offline ChrisV289
Re: Grommets for '65 Fastback Trunk Lid
« Reply #1 on: April 04, 2011, 06:46:35 PM »
Are you referring to the plastic caps that go along the trap door screws?  NPD startes selling them recently.  I know a gentlemen was reproducing them as well. You would need the clear/opague colored ones.
2009 V6 Mustang Coupe
Offline Murf
« Reply #2 on: April 04, 2011, 07:09:40 PM »
The little tiny white bushings you need are one of the most obscure parts in the Mustang world.  I have only seen one car with those still intact, an unrestored 65 Shelby that Bob Perkins had at the Spfld Illinois MCA National a few years ago.  Owned at that time by a fellow whose last name was Stein I think.  Those little bushings are going to be very difficult to find.  I have somewhere an image of them, and have provided it to a couple of people in the past as they expressed an interest in reproducing the part but so far no results.  Good luck on your search, I have been searching for one since 1986 with no luck.  They must have been destroyed about the second time the trunk was opened.
John Murphy
Offline Brant
« Reply #3 on: April 04, 2011, 07:37:09 PM »
I have seen these on lots of '65's,
by late '65 and into early '66, I do not believe that they were used:
very late '65 SJ car above.
original paint later '66 SJ car above.
Offline Vonzeek
« Reply #4 on: April 16, 2011, 03:35:07 PM »
Just wondering if these grommets would be made of nylon, teflon, or a plastic. Should not be hard to get some made up by someone with a lathe and some material. I don't see a split in them, I guess they must be slid onto the torsion rod and pushed into place?
Glenn.
