Author Topic: Carb ID Tag  (Read 3446 times)
Offline Skyway65
  • Gold Level Subscriber
Carb ID Tag
« on: April 03, 2011, 08:43:15 AM »
I need to get an ID tag made for my '65 200 6 cyl. I wanted to verify that the carb was installed on the engine as the engine was assembled so that the date code on the carb. ID tag would be a few weeks before the assembly date of the engine. Does that sound correct?  Thanks--Gary
Gary Schweitzer
MCA #00181
Traverse City, MI
Re: Carb ID Tag
« Reply #1 on: April 03, 2011, 09:19:46 PM »
Gary - Dearborn car??
Offline NEFaurora
Re: Carb ID Tag
« Reply #2 on: April 03, 2011, 11:00:51 PM »
I would not go - nor have I ever seen any tags go futher than three weeks ahead..
You can find the correct codes in Kevin Marti's new book that came out last years.  All of the carbs and date codes are in there.. I double checked mine with it.
Hope this helps Gary.
Tony K.
MCA#70001
Offline NEFaurora
Re: Carb ID Tag
« Reply #3 on: April 03, 2011, 11:01:51 PM »
Oh yeah... Kevin makes the repro tags too....  :o)
Tony K.
MCA#70001
Offline Skyway65
Re: Carb ID Tag
« Reply #4 on: April 04, 2011, 08:52:52 AM »
Jeff--Dearborn car--the engine was assembled in Dec of '64 and the exhaust/intake manifolds are Nov of '64.  So was the carb installed as the engine was being assembled?  It too should be Nov of '64 too.  Right?
Thanks for the Marti info Tony--I don't have the book-just need the info! ;D
« Last Edit: April 04, 2011, 09:18:40 PM by Skyway65 »
Gary Schweitzer
MCA #00181
Traverse City, MI
Re: Carb ID Tag
« Reply #5 on: April 04, 2011, 09:40:40 PM »
From pictures it appears that engines were shipped with carbs attached so IMHO yes
Offline Skyway65
Re: Carb ID Tag
« Reply #6 on: April 05, 2011, 08:43:43 AM »
Thanks Jeff-that's what I thought too but I wanted to verify that.
Gary Schweitzer
MCA #00181
Traverse City, MI
Re: Carb ID Tag
« Reply #7 on: April 05, 2011, 10:02:47 PM »
No problem we all confirm details all the time. Rather double check than redo ;)
Offline bryancobb
  • Silver Level Subscriber
  • 2009 Ridn' Around
Re: Carb ID Tag
« Reply #8 on: April 27, 2011, 04:14:15 PM »
66 Metuch Conv
Nightmist, Std Blu Int
Offline Skyway65
Re: Carb ID Tag
« Reply #9 on: April 29, 2011, 12:57:20 PM »
Thanks Bryan-need to get the car finished first. Then the the little details will fall into place. 8)
Gary Schweitzer
MCA #00181
Traverse City, MI
Offline bryancobb
  • 2009 Ridn' Around
Re: Carb ID Tag
« Reply #10 on: April 29, 2011, 01:37:47 PM »
Yeah Gary,
I understand.  I just had NEVVVVER seen one of these ignition keys.
66 Metuch Conv
