Author Topic: Search question from a noob  (Read 936 times)
Offline bburns31
« on: November 16, 2022, 12:02:46 AM »
I apologize in advance but I've spent an hour trying to find the library post about cleaning a driveshaft. My search results always come back empty. Is there a good reference for detailing a driveshaft and 8" diff/rear end?
« Last Edit: November 16, 2022, 05:04:48 PM by J_Speegle »
66 Mustang Dearborn C Code Sauterne Gold Metallic
Re: Question from a noob
« Reply #1 on: November 16, 2022, 12:15:51 AM »
Go to the "Search" feature located in the top line of the page, the first word of the line is Home in a rectangle. Type in "driveshaft cleaning" - do not use the letter "a" (our system does not like single letters). I found 17 topics in addition to your question.
« Reply #2 on: November 16, 2022, 02:24:03 AM »
Short answer: evaporust
« Reply #3 on: November 16, 2022, 11:50:22 AM »
That's because it's called a driveline in the Library.
According to some automotive texts the driveline includes the clutch, transmission, driveshaft and rear axle.
http://concoursmustang.com/speegle/Articles/Article_Driveline_Restoration.pdf
To be fair it's called different things in different parts of the country, just like the removable 3rd member can be called a pig.
Note that rust pits cannot be removed without impacting tube strength.
Then the answer is Deadnutson.com
« Last Edit: November 16, 2022, 01:24:33 PM by Bossbill »
« Reply #4 on: November 16, 2022, 01:37:34 PM »
On the 8" issue it's true this is a difficult search due to one letter or number not being valid in the search box. You can get around this by using the wild card after the single letter/number using the "*" character. Like "8*". Unfortunately, this results in too many results to be useful.
You don't list a year (look at my sig for an example of what to post) and your future posts will net many more correct responses if you include the car details.
I used the following in my search (for all years and models):
8inch restore
with this one being a good start if you have a 66 Mustang:
https://www.concoursmustang.com/forum/index.php?topic=8550.0
