First of what should be many surveys. This thread is posted to collect data related to the position of the tire pressure decal applied to original 66 Mustangs build at Metuchen. To participate please read the following. Understand that this is not an often seen detail but in the same way its possible that since the location was less exposed we might find a higher percentage of originals verses reproductions.
- This is ONLY for 1966 Metuchen Mustangs
- Participants need to provide the cars VIN and the projected build date from the original door/warranty tag. If you happen to have the original date of sale that might help also
- If the glove box liner has been replaced don't post unless you have an original decal attached to the glove box door.
- If yours has one applied to the glove box door. Where is it attached
- Picture would really help confirm things.
So here is what we have so far for 1966 NJ Mustangs.
Pretty wide area of unknown. We need to keep an eye open for more original examples to tighten it up
6T135xxx - Highest sequential VIN with decal attached to glove box door drivers side
6T24357x - Lowest sequential VIN with decal attached to the glove box liner passenger side
6T07C10443x
6T09K12xxxx
6F07T12725x
6T09C24357x
6T07C26694x
6T09C28607x
So apparently the change was for all 66 Mustangs at multiple plants for some unknown reason. Can't think of a reason for the change or why it was important enough to make a change
