Author Topic: Amp wire clip  (Read 1653 times)
Amp wire clip
« on: November 05, 2022, 11:29:53 PM »
I've seen a number of Shelbys with a hole in the pax shock tower. Pic 1 is of my car.
This pic, an extraction from one of Jeff's Unrestored car pics (https://www.concoursmustang.com/forum/index.php?topic=13542.msg83513#msg83513), is from a later March 67 car. It's also one of the few cars I've seen with the hole filled with a clip to hold the amp wire.
I'm not sure if the clip is SAI provided or not. Any information appreciated.
« Last Edit: November 06, 2022, 10:26:10 AM by Bossbill »
Re: Amp wire clip
« Reply #1 on: November 06, 2022, 12:02:25 AM »
I'm not sure if the clip is SIA provided or not. Any information appreciated.
Yes SA added a repurposed Ford clip.Typically seen on the sheath covered amp wires but carried over to some of the tape wrapped amp wires too.
Re: Amp wire clip
« Reply #2 on: November 06, 2022, 01:11:11 AM »
Interesting.
I'll have to ferret around and try to find one.
Thanks Bob.
Offline 67350#1242
Re: Amp wire clip
« Reply #3 on: November 06, 2022, 08:36:41 AM »
Try AMK.  I think that is where I found one a few years ago.
67 Coupe SJ 11/16/66
67 GT350 SJ 2/01/67
Re: Amp wire clip
« Reply #4 on: November 06, 2022, 08:49:02 AM »
Is that the same as the ones in front of the radiator on all 67's?
Re: Amp wire clip
« Reply #5 on: November 06, 2022, 01:17:58 PM »
Yes, there are 4 on the lower, front crossmember.
Thanks for the PM Jim. It is P-clamp 377359-S. At NPD it is
https://www.npdlink.com/product/clips-wiring/196038?backurl=search%2Fproducts%3Fsearch_terms%3Dront%252Bcrossmember%26top_parent%3D200001%26year%3D1967&year=1967
For a Shelby you need 3 pair (5 needed; sold in pairs).
After I tried to fit a spare clip from the parts car to the location noted in pic 2 I see that you have to put this in place before the export brace is bolted down.
« Last Edit: November 06, 2022, 01:25:12 PM by Bossbill »
Re: Amp wire clip
« Reply #6 on: November 06, 2022, 03:56:59 PM »
Last time I needed these and were using reproduction parts on the car I just bought a package of the 67  front cross member clips. Will see if I have any extras  ::)  Bill PM me with how many you need if you would
