Guys I was wondering if I can dip control arms using hydro-dipping...
Not sure which water to use for filling up a bucket of water...Tap water or distilled.
Next using either aerosol to spray in the water or use 1 qt of Rust-oleum Semi-Gloss oil based paint Can and dip it in the water.
At first I was thinking of getting a 2 gallon Rust-Oleum but that would be super expensive at 180.00 and would be a waste of product when I'm finished.
The only thing I'm not sure if surface Rust can form under the paint from having water mixed with paint. If the paint is oil based then I'm not sure there will be surface rust under the paint. When I remove original dipping from UCA and LCA I do find surface rust under the paint.
Pictures are just an example of UCA and LCA...I have many...
https://www.ebay.com/itm/134261414315
