Author Topic: New upholstery  (Read 1209 times)
Offline 68 GT
New upholstery
« on: October 24, 2022, 03:59:59 PM »
Does anyone have any advice on where to buy new seat padding and upholstery for our 67 coupe? I?ve heard that people are having a hard time getting upholstery for some reason. Thought that maybe I?d better go ahead and get some ordered in case it has a long lead time. The Marti Reort says the cars interior was 2B Blue Vinyl Standard Bucket Seats.
VIN 7T01C246XXX
Actual build date 5-11-67
VIN 8F01J208XXX
Actual build date 6-27-68
Re: New upholstery
« Reply #1 on: October 24, 2022, 04:01:22 PM »
i would give NPD a call.
Re: New upholstery
« Reply #2 on: October 24, 2022, 04:38:37 PM »
Only a couple of suppliers of things like this if I recall correctly (upholstery kits rather than custom made) so your left choosing based on service and suppler of the reseller. One thing to consider it that larger resellers may get their supplies quicker and may have more leverage if a problem arises. Would not suggest to base the choice solely on price.
Re: New upholstery
« Reply #3 on: October 24, 2022, 04:58:55 PM »
I believe that TMI products, is the main supplier of reproduction upholstery to the Mustang community.
Offline 68 GT
Re: New upholstery
« Reply #4 on: October 24, 2022, 05:49:50 PM »
Looks like I can order from TMI Products. NPD also sells TMI upholstery, but when you mentioned larger resellers, do you mean buy straight from TMI? NPD looks a little cheaper for the same product.
VIN 7T01C246XXX
VIN 8F01J208XXX
Re: New upholstery
« Reply #5 on: October 24, 2022, 06:44:26 PM »
In times where supply chain can get in the way or other times where there can be production issues I would go with a reseller. They may have the product in stock or already have an order for a number of kits while if you contact the company directly you would be placed in line after them. As mentioned they have more leverage that you would given their purchasing power. They may also be able to offer it at a lower price since they will be purchasing from the supplier on a volume basis or might be overstocked on some kits.
Re: New upholstery
« Reply #6 on: October 24, 2022, 09:10:25 PM »
As far as the foam cushions I would strongly suggest that you buy the best quality foam. The cheaper foam is hard as a rock. Better yet clean and repair your original foam, if at all possible. It is better than any you can buy.
Offline 68 GT
Re: New upholstery
« Reply #7 on: October 25, 2022, 12:48:42 AM »
Thanks for the replies! Would you suggest a good quality foam fromTMI? Seems like NPD is a good place to order TMI products from. On a side note, what is considered an early model vs a late model year Mustang? What is the cut off point for model years early and late? I?ve often seen people saying, or asking, if their Mustang is an early or late year build.
VIN 7T01C246XXX
VIN 8F01J208XXX
Re: New upholstery
« Reply #8 on: October 25, 2022, 01:43:04 AM »
........................... On a side note, what is considered an early model vs a late model year Mustang? What is the cut off point for model years early and late? I?ve often seen people saying, or asking, if their Mustang is an early or late year build.
We often use "early" and "late" to describe running changes and in those examples it normally just identifies which came first. As for early and late build IMHO an earlier car could be anything built before mid year or after the middle of the production year while others may use the beginning of the year to divide the year in two halves. For myself, when I use the term "early" for a build time I'm referring to cars built from the start of production to maybe November. While late is after May or so the following year. Isn't scientific or mathematical I know Sure each of our definitions will be slightly or more different
Like so many things in this hobby (matching numbers, restored, concours, original) you often have to ask what the writer or speaker means by that term to get a clear idea of what they mean.
Re: New upholstery
« Reply #9 on: October 25, 2022, 09:55:49 AM »
Yes, I would recommend NPD's best quality foam.
Re: New upholstery
« Reply #10 on: October 26, 2022, 04:59:06 PM »
Doesn't Distinctive Industries not still make and supply kits? Seem to still see them advertised
Offline 68 GT
Re: New upholstery
« Reply #11 on: October 27, 2022, 11:30:44 AM »
Hmmm?.. I?ll have to check them out! Thanks Jeff!
VIN 7T01C246XXX
VIN 8F01J208XXX
Offline Flade
Re: New upholstery
« Reply #12 on: October 27, 2022, 09:25:28 PM »
Distinctive and TMI are the Primary suppliers for Mustang upholstery.   I compared both When I did my 68.  Neither was perfect but TMI was closer to original.  I also found the repro Foam was terrible.  I reused my original foam and added an additional layer of foam over it.  Very pleased  with the results.  I did a detailed thread on it at VMF
https://www.vintage-mustang.com/threads/68-seat-reupholstery.691825/#post-4787161
68 Convertible, 289 C4, SJ May 68 build date
