Author Topic: 1968 Fastback Fold Down w/o rear chrome  (Read 816 times)
Online Kascus
« on: October 22, 2022, 10:07:01 PM »
I have the late 68 FB with the fold down seat that does not have the rear chrome trim where the trap door latch goes. From the factory, it was glued and stapled along the rear edge instead of having the chrome piece the early models had. When replacing the carpet, will the glue  hold or do I need to somehow try and get staples in also? I am not sure how to get staples through the metal except push through the original holes by hand.
Current:
1964.5 289 D Code Coupe / Dearborn 06-05-64
1966 289 C Code Convertible /San Jose 02-11-66
Past:
1965 Shelby SFM5S561
1968.5 428 CJ Fastback / San Jose 05-15-68
1966 289 FB
1965 289 Coupe
1969 302 Fastback
Re: 1968 Fastback Fold Down w/o rear chrome
« Reply #1 on: October 22, 2022, 11:41:56 PM »
Replace the staples and glue would be the correct and original method. You can make your own staples and yes insert and crimp them by hand.
Pretty much just like the radiator support seals on some of our Mustangs and Shelby's
Often no easy button to restoring or being original but it will pay off in the long run  :)
Online Kascus
« Reply #2 on: October 23, 2022, 12:08:59 AM »
Thanks, trying to make this one as close to concours as possible.
Current:
Past:
1966 289 FB
1965 289 Coupe
1969 302 Fastback
Online jwc66k
« Reply #3 on: October 23, 2022, 12:50:38 AM »
If you have any of the old staples, measure the diameter. I've found that either 0.025 or 0.030 inch diameter safety wire can be used as a replacement. Cut the wire to length, then bend the ends to a "U" shape to fit the existing hole spacing, install, crimp (and don't tell anyone what you did).
Online Kascus
« Reply #4 on: October 30, 2022, 02:55:25 PM »
My old staples did not survive the removal and I no longer have them. I was able to use 5/16 staples and crimp them with needle nose vise grips. The hardest part is finding the tiny holes and lining up a staple. I found a flashlight shinning from the backside really helped out the process.
Current:
Past:
1966 289 FB
1965 289 Coupe
1969 302 Fastback
« Reply #5 on: October 30, 2022, 04:38:32 PM »
For others the ends were originally a bit longer and were curled on the back side by the machine just like the ones used on the radiator support seals at Dearborn
