Author Topic: Sway bar end links  (Read 387 times)
Offline 68 GT
Sway bar end links
« on: October 20, 2022, 01:07:22 PM »
Trying to install new sway bar end links on a 67 restoration. Any tricks to compress the rubber bushings on the end link so I can install the sway bar? Install the end links first then the 2 brackets to the frame rails? Thanks for any advice or tips!
VIN 7T01C246XXX
Actual build date 5-11-67
VIN 8F01J208XXX
Actual build date 6-27-68
Re: Sway bar end links
« Reply #1 on: October 20, 2022, 02:08:57 PM »
The sway bar is totally in the way when it comes time to install the engine so I usually leave it until last thing. It's best to loosely install the frame brackets first, then assemble the end links.
Offline 68 GT
« Reply #2 on: October 21, 2022, 06:41:03 PM »
Thank you for the reply. I have removed the sway bar, end links and frame brackets until the engine is back in the car. I appreciate your advice!
VIN 7T01C246XXX
VIN 8F01J208XXX
