Author Topic: unknown holes in firewall  (Read 2409 times)
Offline S412gofast
« on: October 14, 2022, 12:59:37 PM »
We are getting all in accord to install engine in 67 GT350 1341 and I now noticed the 2 holes circled in red.  Can anyone identify if these are factory or Shelby added or if I need to remove them.
Carl
1967 GT350 01341, FORD Build: 2/28/67 ; SAI Build 3/28/67
1966 GT 2+2, 4spd, PS, tinted windows, Raven Black w/Black Pony interior; FORD Build: 10/11/65
1986 SVO, Oxford White w/Leather interior
1987 Saleen #132 Dark Gray Metallic
Re: unknown holes in firewall
« Reply #1 on: October 14, 2022, 04:03:27 PM »
Slightly off topic, but I notice the unevenly spaced holes on the firewall for the export brace. Have you?
« Reply #2 on: October 14, 2022, 06:43:24 PM »
No telling why there are holes there. Not factory and not typical of any 1967 Shelby.
« Reply #3 on: October 15, 2022, 02:53:21 PM »
Carl
You need to remove the holes if you want the firewall to look factory original.
« Reply #4 on: October 15, 2022, 02:54:44 PM »
The cowl brace hole pattern in the picture is typical of 67 Mustang.
« Reply #5 on: October 15, 2022, 04:04:54 PM »
The topic is about a 67 GT350.
« Reply #6 on: October 15, 2022, 05:42:16 PM »
The hole pattern is the same regardless of it 67 Mustang or GT350.
« Reply #7 on: October 15, 2022, 07:03:49 PM »
Thanks for the clarification.
« Reply #8 on: October 16, 2022, 11:54:03 AM »
Oddly enough my Shelby, built in the same week, has a similar punched in hole.
I'll have to run a screw through it, but thought it was for the ground strap, albeit incorrectly located.
Are there any late February or early March '67 SJ cars with similar holes?
(I need to check the parts car as soon as I get over this cold).
« Reply #9 on: October 16, 2022, 04:04:11 PM »
Mine is further over than Carl's pic.
What is weird is that the holes are not drilled but punched leaving a crater.
I'll dig into my disassembly pics and see if there is anything there.
So far it's just an odd coincidence and that our cars are not that far apart on Ford build date.
Update pic to add red circle.
« Last Edit: October 21, 2022, 12:14:02 PM by Bossbill »
Offline S412gofast
« Reply #10 on: October 16, 2022, 04:17:08 PM »
Bill I am thinking like you on this.  If someone wanted an extra hole in the firewall they would just drill it.  I do not think it is easy to create a hole like we have on our firewalls by punching method in these radiused areas to result in a hole within a depressed crater.
« Last Edit: October 16, 2022, 04:21:45 PM by S412gofast »
« Reply #11 on: October 16, 2022, 05:37:18 PM »
I'm reluctant to drill a hole in the firewall as I don't know what's on the other side. An awl or punch "seems" safer.
« Reply #12 on: October 16, 2022, 05:49:27 PM »
I thought Ford liked to do punched holes since the metal deforms and splays giving a lot more surface for a metal screw to bite.
This looks rather severe.
« Reply #13 on: October 16, 2022, 06:01:59 PM »
I found some pics of when the car was up for sale. Yes, I keep almost 40 year old pics. The hole was there with nothing in it.
This car once had aftermarket air due to its location in the deep south. Lots of holes had to welded up. If I put my smart cap on this may well have been a way to feed a 12V electric line directly in-line with the inside evaporator. It could also be a way to to send power to the A/C clutch.
Time to make that hole go away.
« Reply #14 on: October 16, 2022, 06:27:43 PM »
Elementary, my dear Watson.
Sherlock.
