Author Topic: Educate Me Please  (Read 1257 times)
Offline rcode1966
Educate Me Please
« on: October 07, 2022, 10:21:09 PM »
Hi do you decipher the date codes on ignition coils...THanks
Re: Educate Me Please
« Reply #1 on: October 07, 2022, 10:23:25 PM »
Did I not include that in the date coding article in the Library?   Going to have to look into that
« Reply #2 on: October 07, 2022, 10:25:05 PM »
Checked and it there on page #33
Article it titled - Date Codes - Decoding Date Codes
« Reply #3 on: October 08, 2022, 12:45:13 AM »
FYI the date code is part of the ink stamp on the body. The molded letter and number on the top of the yellow portion of the coil is not the date code.
« Reply #4 on: October 08, 2022, 01:07:38 PM »
A slight "correction". The date code stamp is applied to the coil as a second operation. It is applied within the basic coil stamp in the rectangle on the right. Most of the time it looks OK, but it does get smeared.
Attached is a usable sample of the coil stamp that most stamp making shops can use to make one. If I remember, the date code letters are 12 point Calibri type.
Offline rcode1966
« Reply #5 on: October 08, 2022, 08:44:01 PM »
Jim, your diagram brings up another question I had, when was the switch from the Fomoco coil to the Autolite coil....
« Reply #6 on: October 08, 2022, 10:01:52 PM »
Did you read the prior threads on the subject? Over 10 plus years allot of subjects have been covered  so its always good to start with a search
Added
With what is on page #33 of article and my records somewhere between April and June 1966. Exact date may different slightly depending on where the coil was made if the supplier and more than one plant. Sort of like The switch from the castings on a V8 Fuel pump
« Last Edit: October 10, 2022, 02:45:22 AM by J_Speegle »
« Reply #7 on: October 10, 2022, 12:51:47 AM »
Not Jim but sometime in the latter part of 66 production.
