Author Topic: 1966 coil spring...Black paint or raw steel  (Read 4371 times)
Re: 1966 coil spring...Black paint or raw steel
« Reply #15 on: October 15, 2022, 11:56:21 PM »
I just copied the paint marks as they initially were.  Probably that worker was careful.  Took me one minute to do the stripes.  1/2 inch stripes as I measured them.  Mine are almost 3/4.
If you cut the time to 5 seconds it will look a lot better.
Offline Maksim27
« Reply #16 on: October 16, 2022, 03:10:10 AM »
So just brush all at the same time.
« Reply #17 on: October 16, 2022, 09:39:49 AM »
yep. when recreating items like this try to place yourself in the installers mind set. you have just so much time to complete the task. do it once & then don't fudge with it. same theory goes for most parts installations.
« Reply #18 on: October 16, 2022, 01:05:54 PM »
For the correct atmosphere, take a sip of coffee while "painting", with a lot of background noise of course.
« Reply #19 on: October 16, 2022, 10:25:01 PM »
Just depended on how hard he pressed the brush and in turn how much the bristles spread. IN general there was not allow of pressure produced since it was a quick pass and pressing would slow down the process
Offline Maksim27
« Reply #20 on: October 16, 2022, 11:20:06 PM »
Will the springs get points taken off the way they look with the paint stripes being too perfect.
« Reply #21 on: October 17, 2022, 01:41:48 AM »
Would depend on how visible and the judge. Most likely if they were going to they would more likely just make a written comment. Or at least that is what I would expect.
In the class your likely entering you don't have to have paint marks but if they are incorrect then you are open to deductions. SO it depends entirely on the judges in the teams knowledge, experience or what they may have picked up here :)
