Author Topic: fomoco stamp on radiator  (Read 1455 times)
Offline silverelvis69
« on: September 21, 2022, 03:53:48 AM »
Hi all,
Is there a fomoco stamp that can be placed on an alluminium radiator to make it look OEM
see below.
I am tempted to grind out my old radiator but dont have the heart to do this incase it needs to go to a better home?
San Jose built
11/69
Dark ivy green metallic
Ps A/c
Re: fomoco stamp on radiator
« Reply #1 on: September 21, 2022, 04:11:15 AM »
Actually , did the 70's produce this FoMoCo stamp on radiators back in the day?
The radiator I have is off a 67
San Jose built
11/69
Ps A/c
« Reply #2 on: September 21, 2022, 09:48:10 AM »
Hi all,
see below.
There is not anything ready made . I would make a mold of the one on the Ford radiator then epoxy the FOMOCO onto the aluminum radiator before cutting up a good brass top tank.
Offline cobrajet_carl
« Reply #3 on: September 21, 2022, 11:49:27 AM »
So far all of my original 70/71 radiators have had the FoMoCo stamp. But I have seen other radiators without it but with the part number stamped on the side. Might have been a replacement tank but looked original.
Carl
70 and 71 Dearborn mach Is
« Reply #4 on: September 21, 2022, 03:34:40 PM »
Yes I believe 70 had a FOMOCO trademark . The difference in the trademark style most likely has to do with the Modine plant servicing the SJ plant vs the Modine plant servicing the Dearborn or Metuchen plant. I have seen the picture on the left trademark on SJ radiators for example and the one on the right is more typical on radiators used at the eastern plants.
« Reply #5 on: September 22, 2022, 05:53:21 PM »
How do propose to make a mold?
I agree, I dont want to cut the brass radiator as it is talking to me and needs to go to a home for someone to go concourse
San Jose built
11/69
Ps A/c
« Reply #6 on: September 22, 2022, 06:36:12 PM »
I have used wax,JB weld and pam for a release agent. The internet ,You tube etc. for more how to info. You will have to think outside the box on some aspects I  believe.
Offline Anghelrestorations
    • Anghel Restorations
« Reply #7 on: September 23, 2022, 02:38:54 AM »
All the 70 radiators I have ever seen have the FoMoCo stamping on the top.
Why do you want to go thru the effort of making a mold, stamp etc?  I assume your tank is missing this?  I would assume its easier to just find a replacement radiator or top tank.
Marcus Anghel
www.anghelrestorations.com
« Reply #8 on: September 23, 2022, 09:11:55 AM »
he is trying to fake a correct appearing radiator. his rad is aluminum. i can't believe he is being encouraged.
« Reply #9 on: September 23, 2022, 06:38:49 PM »
Not going to be much of a "fake" or copy given there are likely dozens of things that will look very different
IMHO it will be like putting a AUTOLITE sticker on a solid state voltage regulator with the short bare case  ::)
« Reply #10 on: September 26, 2022, 08:04:23 AM »
Got the idea here
3min 42 in
San Jose built
11/69
Ps A/c
Offline Blues Power
« Reply #11 on: November 29, 2022, 09:56:48 AM »
my original 70 Rad had the ford markings.
foolishly i tossed it 35 yrs ago along with the original purple dab shocks and a bunch of other stuff i caulked up as old junk
« Reply #12 on: November 29, 2022, 12:08:14 PM »
A aluminum radiator is a expensive investment. If encouraged by you means suggesting a alternative to
 a doomed to fail cutting up a brass top tank for a trademark then guilty as charged.  ::)
