Author Topic: Wheel Well Undercoating  (Read 3337 times)
Offline ChrisV289
« on: March 27, 2011, 02:25:58 PM »
What's the best way to remove sound deadener/undercoating from the front frame rail without damaging anything underneath it?  Curious to see if anything lies underneath like the rotation number, etc...
2009 V6 Mustang Coupe
Re: Wheel Well Undercoating
« Reply #1 on: March 27, 2011, 04:33:47 PM »
Any chemical you use will remove anything underneath.  Your best chance might be a heat gun and putty knife.
Online midlife
« Reply #2 on: March 27, 2011, 09:27:06 PM »
I have used gasoline, a rag, and elbow grease to remove undercoating.  It works quite well and does not remove most automotive paints.
Of course, one has to apply common sense and do this in a well-ventilated area.
« Reply #3 on: March 27, 2011, 10:05:04 PM »
diesel fuel also works. not as flammable either.
Online midlife
« Reply #4 on: March 28, 2011, 09:34:29 PM »
Diesel fuel will work too, but it tends to leave a greasy film afterwords.  Gasoline is also a bit cheaper!
« Reply #5 on: March 28, 2011, 10:17:23 PM »
Would not expect to find any markings  (though it you discover something lets see ;)  on the front frame rails unless its a San Jose built car or around the steering box bolt location    :-X
Offline ChrisV289
« Reply #6 on: March 28, 2011, 10:19:41 PM »
It is a San Jose car, so I have my optimism since I saw one this weekend (66 coupe) that had the number written on it.  Thread is located in the 64-66 section.
« Reply #7 on: March 28, 2011, 11:19:47 PM »
Should have the fender locator numbers written there  - same set of numbers that were used over and over on thousands of Mustangs. Just not always the same numbers ;)
Good luck
