Thanks Jeff. It has been exciting to get started. Upon further inspection, the red has been painted on areas that would not have been painted, so that makes sense. I have a Deluxe Marti report that came with the car, but where can I find a past set of MCA judging sheets to know what the paint colors/markings should be for the axle and undercarriage (and other areas).
There is no sheet or document made by MCA or anyone else for markings and such. For details just restoring I suggest bypassing MCA judging sheets and use the good forums to find and provide those such details as judging sheets are limited by space and don't have illustrations nor pictures to help show the details. Also understand that some of the cars built at the multiple car assembly plants share details and marking while other marks it will depend on the assembly plant and time period the car was built. So there are likely thousands of different combinations if you were to look for all of the markings that might have been applied to your car. It takes me about 8-10 hours to put together a list
And of course this post could not be complete if I didn't mention that you should not just copy marks you find on the interest or from other 69s since you often don't know that cars details or if restored if they made up the markings, assumed things based on what they had heard, or borrowed them from completely different cars. The search starts with your car on those original parts. Clean carefully, document, research and confirm the marking then consider reapplying them. For the missing or typical ones we can discuss those here - seems to be the place
Since your new you might also want to look through the Library section of the site now that you have access to it. Besides others there is an Article on basic paint markings that should provide some areas and parts to check on your car fro markings. Also another source is your cars original build sheet though it will show how the part was to be marked and not always exactly how it was marked
Lastly we suggest you don't worry about paint marks unless every other details has been address and made to replicate the original look. Nothing IMHO looks more out of place than a correctly applied paint mark on a poor reproduction part on one finished incorrectly. Think we've all seen those cars. Even worst is the cars with lots of wrong or incorrectly finished parts and marks and stickers that are incorrect.
Like these
Easy to see some things should have been addressed before they thought about paint marks
Yes that is the #2 bolt in cross member in the upper left with what was likely the sway bar marks from a later car
Alternator has multiple issues
Plenty of things but wanted to point out that the buyer/owner cut apart stickers to make the one on top of the PS pump.
Why?
Example of a replacement part taken out of the box, someone slapped a paint daub on it and installed it as is. Car was a NJ built car so most of you will notice other details related to the thread subject
