Author Topic: Ball joint paint markings  (Read 560 times)
Offline Flade
« on: September 04, 2022, 05:57:13 PM »
Was the paint applied to the ball joint threaded sections applied with a brush, spray or dipped?
68 Convertible, 289 C4, SJ May 68 build date
Re: Ball joint paint markings
« Reply #1 on: September 04, 2022, 07:07:42 PM »
OK, from the top - year, (model), (date), engine and plant.
Sloppily, with a brush.
Offline Flade
« Reply #2 on: September 05, 2022, 04:04:13 PM »
Thanks jwc
Not sure how the rest got cut off?.
68 convertible, 289, San Jose, 28 May build date
« Last Edit: September 05, 2022, 04:47:07 PM by Flade »
« Reply #3 on: September 06, 2022, 06:32:14 PM »
Brush before they were attached to the a arm so a fair amount of paint would be knocked off the threaded surface when the nut was installed on an original
Offline Flade
« Reply #4 on: September 07, 2022, 12:56:11 AM »
Thanks, that what I figured.   Is there a preferred paint to use?
« Reply #5 on: September 07, 2022, 01:00:58 AM »
No any school bus strong yellow will work. Likely would choose a typical favorite enamel or a small Rustoleum If you have a typical car and especially a PS one you will use a fair amount of paint  so that is the reason I'm not suggesting the small hobby bottles
Offline Flade
« Reply #6 on: September 07, 2022, 01:52:21 AM »
I?ll grab a can of rustoleum tomorrow.  It?s a PS car, so pretty much everything gets some yellow it seems.
