Author Topic: Is this the correct fuel pump for a 1966 200?  (Read 757 times)
Offline dsielke
« on: September 02, 2022, 12:10:29 AM »
Does this fuel pump look correct for a Dec. 1, 1965 build date, San Jose, 200 with auto? I read a 4092 was correct for a 66 pump, but wanted to make sure.
« Last Edit: September 03, 2022, 04:54:54 PM by dsielke »
6R09A138419: 1966 GT Fastback, Springtime Yellow
6R08T138429: 1966 Convertible, Tahoe Turquoise
Offline daniel94
Re: Correct 1966 200 fuel pump?
« Reply #1 on: September 02, 2022, 01:40:45 PM »
Dec. 1, 1966 would be a 1967 model year.  Are you sure of the date?
I believe that generally, 1966 model year pumps should have screws around the diaphragm with the inlet horizontally toward the back of the car and the outlet vertical from the center.
What you have appears to be the '67 and up version, which will functionally work but is not visually correct.
Offline dsielke
« Reply #2 on: September 02, 2022, 02:00:43 PM »
Oops, my mistake. I meant Dec. 1, 1965. It was my understanding they used both, the ac 40290 & carter 4092, but not sure of when they switched or if they were used at the same time or different factories.
https://www.concoursmustang.com/forum/index.php?topic=7014.msg39794#msg39794
« Last Edit: September 03, 2022, 04:56:03 PM by dsielke »
« Reply #3 on: September 06, 2022, 06:54:45 PM »
Don't recall ever seeing an original with a AC pump though they might have serviced them (service replacement parts)  that way in the first year. The MADE IN CANADA or MADE IN USA would be another detail to study and determine if that applies also
