Author Topic: Kelsey Hayes 15x6 Wheels  (Read 1345 times)
Offline kljacobs
« on: September 01, 2022, 08:55:26 PM »
Trying to get some assistance from the experts on what these wheels may be from.  The wheels are stamped Kelsey Hayes 15 X 6 JJ3 on the inside of the rim band.  There is a 7 in the hub mounting area on the front and what may be a 09 9 near the valve stem area.  Any clue as to what the application was?  I appreciate the help.
Kerry
1968 Mercury Cougar GTE 428
1967 Mercury Cougar XR7
1984 Mustang GT350 Turbo
Offline davekelly
Re: Kelsey Hayes 15x6 Wheels
« Reply #1 on: April 11, 2023, 08:49:18 PM »
sorry this reply is months late but it might be to a 68 Shelby steel wheel car.  Measure the center hole..I believe the 68 15x6 KH center hole was just under 2 1/2 ".  backspace was 4 1/4", measured 7' wide and was 16 1/8' in diameter. It has the 4 nubs which is correct for a 68 Shelby and also marked "Kelsey Canada" 15 x 6 JJ on the inside which is also right.  Do you see "K2 over 8 on the rim outer loop by valve stem? Hope this helps-
